585,759 active members*
3,907 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Circles aren't circles, but I don't think it's backlash!
Results 1 to 7 of 7
    Nov 2020
    4
    Post Circles aren't circles, but I don't think it's backlash!
    Hello!
    Just finished up my DIY router build and having a few issues, every time I cut circles, they are coming out squashed along the Y axis (Picture attached)
    I've checked all of the usual info I could find on the forums, its running pretty square and I've checked and double checked any slippage or backlash?
    Does anybody have any ideas before I strip it down any further looking for a loose coupling somewhere or a loose belt?
    I'm generating the code in Aspire and using MAck3 into a PoKeys57cnc
    Thanks for your help!
    1218
    Re: Circles aren't circles, but I don't think it's backlash!
    I think you have already narrowed the search to the likely culprits;belts would be more likely than couplings but its worth checking both.Depending on the feed speeds you are using and the depth of cut it could be the gantry or the spindle mounts flexing.Have you tried locating a dial indicator against the collet nut and pushing with your hand to see how easy it is to deflect the needle?Try it both in X and Y to see if there is a difference in the force needed to achieve the same deflection.
    You're getting flex somewhere in the Y axis.
    Nov 2020
    4
    Brilliant, Thanks!
    Can you explain what you mean by flex? This is just a pen stuck to the spindle mount so there should be very little force involved that would cause flex?
    Nov 2020
    4
    Quote Originally Posted by routalot View Post
    Thank you, I tried at multiple different feeds, and still the same result every time.
    Will try the indicator today!
    Aug 2009
    1570
    ...X and Y following error not the same? This can cause out of round circles. Tune your drivers by doing a feedmove and adjust the Signal Gain
    When the motors start moving, but the machine is lagging behind, also known as backlash.
    When your Y axis gets to the top and bottom of the circle, and changes direction, there's a slight delay before it starts moving in the other direction. It could be just about any mechanical part in your machine causing it, from the drive system, to the frame actually flexing.
  1. Can't cut circles... Help!
    By greygabe in forum Syil Products
    Last Post: 12-23-2013, 06:06 AM
  2. circles arent circles
    By xlr8r in forum DynaTorch
    Last Post: 01-18-2009, 06:26 PM
  3. help with circles
    By phe259 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2005, 01:30 AM
