Complete Soigeneris STDR-4C CNC control system. Purchased new from Soigeneris in 2018 for $1,020. Was setup, used once, and has not been used since. Connects to you computer with a modern ethernet cable, not a slow, outdated parallel cable. Includes three 276oz-in N23 stepper motors and all cables. Originally setup for a Taig micro mill, but will work on Sherline, Seig, LMS, and Habor Freight mills that have been converted to CNC operation.
$700 shipped/insured.
From the manufacturer's website:
The Soigeneris STDR-4C stepper drive is a full-featured, compact, 4-axis stepper drive system. A careful selection of quality components is housed in a heavy-duty aluminum enclosure. A high-quality 48V, 320W power supply feeds the stepper motors through a Gecko G540 drive. Two auxiliary power supplies are also included: a 5V supply for the SmoothStepper and a 12V supply to power external sensors. (Separate isolated power supplies maintain the signal isolation provided by the G540.)
The design philosophy of the STDR-4C was to provide a very solid stepper drive system that was easy to use and easy to expand. We started with a heavy duty aluminum enclosure, a high-quality 48V power supply, and the venerable Gecko G540. All the signals from the G540 were brought out to the back panel to make connections easy. To keep things cool a unique thermal control baffle was used that ensures fresh, cool air is drawn in the bottom and the warm air is exhausted out the top. For systems using motors which draw more than 3A, an optional heat sink is also available for the G540.
A large illuminated power switch starts things up and to help ensure safety, an industrial E-Stop switch was fitted. The E-Stop switch removes power from the main power supply and spindle output while maintaining power to the auxiliary supplies. Two relays were fitted, one supplies power to the spindle outlet and the other controls a set of auxiliary contacts on the back panel. Finally to provide the best performance possible a Smooth Stepper was added in.
Feature List
Heavy duty aluminum enclosure
Gecko G540 4-axis stepper driver
120VAC~240VAC Operation
48V, 320W switch type main power supply
12V & 5V, 5W auxiliary power supplies
Ethernet or USB connectivity with integrated SmoothStepper
SmoothStepper Port2 brought out to the rear panel
Four optoisolated inputs
Isolated VFD output
5A, AC output for spindle motor (same voltage as mains supply)
Industrial, Twist-release E-Stop switch
Illuminated power switch
Exclusive ventilation control system
Includes DB9 connectors, USB/Ethernet cable, and power cables
Weight: 10 pounds
Power: 120VAC/10A, 240VAC/5A
12V and 5V, 5W auxiliary power supplies
4 axis stepper drive, 3.5A per axis max
Spindle Control: Built-in relay (5A max, ~1/2 HP)
Auxiliary relay contacts on the rear panel
Illuminated On/Off switch
Industrial E-Stop switch (twist to release)
Interface: Ethernet, USB or parallel port
Four isolated inputs
Isolated VFD output
