585,938 active members*
3,261 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > G20/21 error 9000 parameters? 21-M
    Mar 2019
    94
    Running a program in single block the error comes up at G20, inch would there be a setting in the 9000 parameters that could cause this? I have the list that came with the machine from 9900-9967 and a few don’t match, if I go to change one it says “all files will be cleared in the part program”. What is the part program?
    Craig
    Re: G20/21 error 9000 parameters? 21-M
    On a machine the part program is the G-Code program that machines the parts.
    Mar 2019
    94
    Thanks, just didn’t want to delete anything important, I only have one test machining program loaded right now
    Aug 2009
    1573
    ...G20 is Inch G21 is MM commands
    Fanuc G-Code List - Helman CNC
    Apr 2006
    111
    Quote Originally Posted by Se5a View Post
    Craig
    Yes, it is option parameter 99xx.
  1. FANUC 15M Parameters 9000 how to enter?
    By posedi in forum Fanuc
    Last Post: 09-26-2020, 01:24 PM
  2. Replies: 1
    Last Post: 04-25-2020, 08:18 PM
  3. Fanuc 0M Parameters 9000-9899 description
    By nik_chris in forum Fanuc
    Last Post: 10-02-2019, 06:33 PM
  4. 11M 9000 parameters
    By chuy in forum Fanuc
    Last Post: 07-25-2007, 03:03 PM
  5. Replies: 2
    Last Post: 02-15-2007, 03:10 AM
