585,729 active members*
5,012 visitors online*
    Mori Seiki Tv 30 Z axis problem
    Hi there!
    I have 2 mori seiki Tv30. One of these two machines always generate some problems. it works the whole day and the next day morning gives some errors. Sometimes the X and Y axis lost the zero point (z70 abs .....)
    the last one : Z axis only goes up. The X and Y ok and set the zero. z axis only moves up and and the ATC not Start the zero adjustment.
    When i use the pulse generaor wheeel the z axisgoes up and reached the 2nd zero point, but not comming down . The controller said:M01operation error 0003Z when try to moving down.
    Before this problem i had Y03amp. uneuipped1 . and s52 servo alarm at z axis but these errors not present now.
    I checked the original parameters and check my other tv30 parameters and it looks ok.
    please help me to find the problem
    thank you
    peter
    Re: Mori Seiki Tv 30 Z axis problem
    hello
    I have a machine mori seiki tv30
    was not in use for long so I lost the parameters.
    I would ask you for help
  1. Mori seiki/ FANUC 10M problem...
    By RogerHq in forum Mori Seiki Mills
    Last Post: 09-25-2017, 09:53 AM
  2. MORI SEIKI SL3 TURRET PROBLEM
    By bbrreid in forum Mori Seiki lathes
    Last Post: 02-20-2015, 03:35 AM
  3. mori seiki FL-2 problem
    By cnyttbircan in forum Mori Seiki lathes
    Last Post: 10-21-2013, 09:58 PM
  4. problem in MORI SEIKI SL-0
    By metoaly in forum DNC Problems and Solutions
    Last Post: 10-07-2009, 07:03 PM
  5. Mori Seiki ZL-15 Startup problem???
    By =ego= in forum CNC Machine Related Electronics
    Last Post: 06-26-2007, 09:07 PM
