585,981 active members*
4,128 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Need help with creating tabs in biesseworks
    I am looking to cut a bunch of small parts from very light stock on a Biesse Rove Plast J. The shop I work for has very limited resources and knowledge, I think tabs would be the best way to hold the parts down but I don't know if this is something I can do in Biesseworks or even have the designer do in Vector works. Sadly this project is a rush so redesigning is rather limited so on the Vector works side it would have to be simple settings only changes. That said any and all advice is welcome.
    Apr 2018
    37
    Re: Need help with creating tabs in biesseworks
    Not sure if it's too late, but adding tabs in BiesseWorks itself is a pain. If you want to add tabs, you can import the files into Aspire or vCarve and simply click the add tabs option.
    Nov 2011
    21
    Unfortunately the tabs function doesn't exist in Biesse works or even in Biesse software generally.
  1. Creating 'holding tabs' or 'bridges'...
    By irwinger in forum Dolphin CAD/CAM
    Last Post: 05-06-2017, 03:43 AM
  2. Creating tabs on a solid part
    By dkrenfrow in forum Mastercam
    Last Post: 04-14-2017, 09:27 PM
  3. Creating tabs in Mastercam x6
    By Stevetotheo in forum Mastercam
    Last Post: 09-17-2013, 03:40 PM
  4. creating biesseworks macros
    By oshaw in forum Commercial CNC Wood Routers
    Last Post: 11-29-2011, 02:15 PM
  5. creating biesseworks macro
    By oshaw in forum CNC Machining Centers
    Last Post: 08-24-2011, 06:24 PM
