I am building my contoll cabinet now and am thinking about fuses. Do I want them and where should I put them?
I have an acorn board running 3 stepper online CL57Y drivers that supposedly draw 5 amps each.
A big help is a copy of NFPA79 "Electrical Standards for Industrial Machinery"
You can find a copy in PDF out there on the web, may be a little dated, but most still applies.
Al.
Albert E.
So say I have your standard mean well DC power supply, I would want a breaker or a fuse between its output and my drivers that can do 150% of the output?
My driver power supply is a 48v 21a DC supply, is that considered bigger than a light load?
I'll look around for the regulation book.
Just to clarify, since your drives are rated at 5 amp input, you would want about a 7 amp slow-blow fuse between the power supply and each drive.
Jim Dawson
Sandy, Oregon, USA
Just as an aside, I much prefer linear power supplies due to their extra ruggedness.
You do not need a regulated supply for steppers-servo's
If, or when they fail, SMPS are much harder to fix.
I would rather pay a little more, out of the gate for reliability.
Just my 2c
Al
Albert E.
Yes, you have to put the fuse in the circuit, Fuse should be fast blown before the acorn board supply.
rest you can go with MCBs, But fuse is more responsive.
