585,687 active members*
4,750 visitors online*
Results 1 to 9 of 9
    Sep 2019
    44
    Vacuum table grid and gasket seal form
    Hello,
    I'm in the progress of making my own vacuum table.
    The grid will be milled into a sheet phenolic.
    At the moment i'm struggling with 2 points:
    1) which gasket seal to choose:
    -Round / rectangle or d shaped.
    If i use a round seal (easiest to find) would i neet to mill the groove with a ballnose bit? so the gasket matches the groove? Or can i go with a straight endmill?
    I'm building an universal table setup with 6 different zones. The contour of the zone i would seal off with the gasket.
    2) Would i mill the grid with the same endmill/ballnose bit (5 a 6mm wide) Or would i use a wider 12mm endmill for the internal grid so i have a better air displacement for the vacuum.
    Input would be appreciated!
    Adam
    Nov 2012
    1267
    Re: Vacuum table grid and gasket seal form
    1. Round gaskets work perfectly fine with flat grooves.
    2. The entire table should be covered with a grid of identical grooves (matching the gasket diameter). That way you can seal off any arbitrary size and shape.
    Sep 2019
    44
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks for the reply.
    Point 2 would be beneficial if i want to rearrange the zones at a later time.
    On the allstarcnc gasket site the tell to use a square seal into a square groove and a round seal into a round groove to have the maximum contact and sealing capacity.
    Nov 2012
    1267
    Quote Originally Posted by DAAD View Post
    The part or the spoilboard will have a flat surface anyway, so I don't know how much that really matters. The machines I deal with use round gaskets without any problems - your mileage may vary. :wave:
    Sep 2019
    44
    thanks for the input.
    I would go for a 8mm round seal. +-5/16 inch.
    What would the gasket size be you are using?
    Aug 2005
    205
    What needs to be mentioned here is that the gasket needs to project above the phenolic surface before placing the workpiece. I've used a 1/4" dia. gasket in a 1/4" wide, square bottomed slot successfully for years. The depth of the slot is typically little more than half the gasket diameter, perhaps 5/32". Once under vacuum, the gasket is compressed in the channel with contact at the sides near the top.
    Also, as a means of economy, I use random lengths of gasket longer than the cumulative gasket channel length (not cut to an exact length) for a given part with ends bedded in adjacent channel. I get my gasket here;
    https://www.mcmaster.com/foam/light-...ne-foam-cords/
    Nov 2012
    1267
    I don't have it in front of me, but it's about 8mm, or maybe 10.
    Sep 2019
    44
    Thanks for the input!
    Jan 2019
    6
    Hello, Hope this isnt too old and I can ask someone with this gasket a question.
    We bought an new industrial cnc in December, (why arent I asking them? Another issue...)
    We applied a gasket they recommended around each vaccum zone. The gasket they recommend sounds like yours where it sits a bit above the phenolic then compresses with the vacuum. Well thats all well and good, but here is our issue. When we for example want to cut from say zone 1 a piece to fit right in there. We would then turn off the other zones, well that compression somes into play and raises that side of the table and messes up my cuts.
    Anyone else have this problem, or am I extraordinarily lucky?
  1. Vacuum Table w/o grid- Will this work?
    By SteveChlupsa in forum Avid CNC
    Last Post: 02-22-2017, 10:53 PM
  2. Double Sided Gasket vacuum Fixture
    By diyengineer in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-03-2011, 10:10 AM
  3. Best Material for Dedicated fixtures to place on vacuum grid
    By 777funk in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-27-2010, 04:15 AM
  4. Gasket material for Vacuum Workholding
    By tminnig in forum MetalWork Discussion
    Last Post: 03-30-2009, 03:04 PM
