586,005 active members*
4,897 visitors online*
Results 1 to 6 of 6
    Nov 2020
    5
    DIY Fibre Concrete 40x30 CNC Mill
    Dear CNCzoners,
    below the link to my brand new video showing the highlights of the fibre concrete CNC built. I thought long about what materials best to use with the tools that I had at hand. I decided to experiment with fibre concrete. I am quite satisfied with the result. Enjoy the video!
    https://www.youtube.com/watch?v=3JwQ6bVTlHI
    Cheers
    TheTinkerLab
    Jul 2018
    6337
    Re: DIY Fibre Concrete 40x30 CNC Mill
    Hi Tinkerer - Well done. Peter
    Jan 2020
    39
    Is concrete going to shrink during the following weeks and months as it cures completely?
    Sent from my SM-G970F using Tapatalk
    Jul 2012
    102
    Nice build.
    But I'm very sceptical about your measurements if you're claiming to have achieved 10 micron flatness by lapping concrete with a piece of MDF
    Also I would be worried that the concrete will shrink and move for many years.
    The UHPC for machine beds made by Durcrete needs 80°C curing during 48h to achieve stability after one week. If not cured at high temp, it needs at least 6 months to stabilise.
    Nov 2020
    5
    Quote Originally Posted by Nikolaguca View Post
    Cement will shrink as it cures (how much?!) but not the aggregate. Depending on the grain size distribution (graining curve) and the cement there will be more or less shrinkage of the concrete, but it it will typically be in the range of a couple of 100 microns per meter (in comparison - thermal expansion of aluminium is about 260 microns per 10°C and meter). With epoxy coating as finish this becomes irrelevant for the final surface precision.
    Nov 2020
    5
    Quote Originally Posted by jackjr-123 View Post
    Nice build.
    Thanks. You should be sceptical :-) I measured it with my dial indicator stuck to a peace of metal, since I don't have any flatness gage (https://www.youtube.com/watch?v=EWqThb9Z1jk). Even if it is double the error, I would still be happy given the cost of a grade B lapping plate! I was "lapping"/sanding epoxy BTW :-)
    How much do you think will it shrink after the first year? Consider a metal machine is most likely standing on a concrete floor as well.
    Thanks for the info and the feedback.
  1. Concrete base idea for mid sized router/mill
    By metalworkz in forum DIY CNC Router Table Machines
    Last Post: 12-26-2016, 02:39 AM
  2. Concrete/cement mill design
    By LazyH in forum Vertical Mill, Lathe Project Log
    Last Post: 01-18-2016, 03:36 PM
  3. Has anyone besides this guy made concrete mill parts?
    By slashmaster in forum Benchtop Machines
    Last Post: 01-22-2011, 12:18 AM
  4. Long term project - concrete mill
    By The Blight in forum Vertical Mill, Lathe Project Log
    Last Post: 04-11-2009, 11:14 PM
  5. Concrete to stiffen mill upright?
    By Tristar500 in forum Benchtop Machines
    Last Post: 11-13-2006, 04:21 AM
