585,930 active members*
3,568 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Can't run spindle with door open on my brand new ST-20Y!
    Jan 2011
    51
    Ok, I've been fighting this door interlock issue since 2009 on my VF4. To bypass the interlock on that machine I just push a bunch of buttons, the locations and order of which I can't even describe to you. I've been doing it so long It's just automatic. Then on my 2012 VF5 I had to remove the "forks" from the doors and stick them into their receptacles and that was all it took....until last year when they upgraded something in the operating system and now I have to pull the forks out to take tools in and out of the machine, put them back in to run a program. With my 2016 ST-30Y I just gave up and left the interlocks alone. The only issue was that the spindle was limited to 500 rpm with the door open but we can live with that. On my ST-20Y that just got setup today, you can't run the spindle at all with the door open!! What the hell?? I have a very important hand polishing operation that needs to be done with the spindle running, obviously, so I have to be able to run with the door open. Anyone care to share their method for disabling the interlock? Feel free to share via direct message if you don't want to risk the scorn of the Safety Sallys.
    Jan 2011
    51
    Re: Can't run spindle with door open on my brand new ST-20Y!
    Anyone? Anyone? I'm just wanting to be exposed to the same risk as every manual lathe machinist has been exposed to since the invention of the lathe in around 1300 BC!
    I'm not familiar with the new setup but can you not just cut the wires and put in a toggle switch ?
    Jul 2006
    297
    we just received a new mill,same thing there is not a option to disable door switch to my knowledge in the control like the last machine (2007)
    i took a feeler gauge and affixed it with magnets under the limit switches on the doors to trick the door into thinking it was closed when it was open.
    i also unplugged the air solenoid for the door lock mechanism.
    this worked for me.
    2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
  1. Spindle rotate while door open
    By NskNsk in forum Haas Mills
    Last Post: 09-04-2020, 12:53 PM
  2. Rotate spindle while door is open
    Last Post: 05-27-2020, 06:02 PM
  3. Replies: 0
    Last Post: 04-26-2016, 12:21 PM
  4. Replies: 8
    Last Post: 04-04-2015, 02:59 AM
  5. 2216 FX Run spindle with door open???
    By Chuck Pressure in forum Fadal
    Last Post: 10-26-2009, 03:26 PM
