#atccncrouter
Attachment 452038
# 2000x4000x300mm*effective working area
# 9.6KW original import Italy HSD*Air Cooling Spindle,24000RPM
#Italy Hetico drilling heads,9+3+1 drilling heads( 9 vertical drilling+3*horizontal,each horizontal is with 2 drilling bit+ 1 saw blade)
# Taiwan Syntec 6MB 4 axis control system*with MPG handle wheel
# Japan Yaskawa servo motor and 1000W drivers, Z axis with brand brake
# 11kw Taiwan Delta inverter
# New type thicker and bigger heavy duty structure, keep machine higher precision
# With Auto loading and unloading platform for 2000x4000mm working sizes.
# Vacuum and T-slot working table, 6-8 areas
# 8 pieces with*Carousal*Tools Changer
# Taiwan PMI/ABBA*linear guide, 25#
# X,Y-helical*rack*pinion,*Z axis with TBI ball*screw
# TBI**ball*screw*from*Taiwan*
# Automatic tool sensor
