585,735 active members*
4,871 visitors online*
IndustryArena Forum > CAM Software > CamWorks > CAMWORKS turning machine tools bug
    Angry CAMWORKS turning machine tools bug
    Hello all!
    I use CAMWORKS 2020 along with SOLIDWORKS 2020 and it doesn't work right.
    I have to say that for milling centers I have no issues at all.
    Problem is occurring only for turning machines and milling-turning machines.
    When I change tool, I select a tool with different size (new one) and when I click "Select" it changes the tool but leaves the dimensions of the previous one. This way I cannot change my tool or make any toolcrib at all.
    I don't find any threads with similar problems, is it just me or everyone has these bugs?
    Also sometimes it wouldn't generate toolpath until I regenerate the whole turn setup, which leads to regeneration all other operations!
    I am very frustrated, and I can't believe that I am the first one to experience such issues.
    Let me know how you handle this situation, please
    Re: CAMWORKS turning machine tools bug
    It sounds like you are selecting the tool properly. So, I would have to see what you are talking about to really get a grasp of what you are witnessing.
    As for the regeneration issue, lathe operations are set to machine Previous Leftover by default in the Turning Tab. So, if you move operations around or change things in preceding operations then you may need to do a full regeneration to get the desired effects.
    Sorry I can't be of more help to your first issue, just can't see what you're witnessing.
  1. Camworks Turning / Lathe and Tool BCA
    By snippitysnap in forum CamWorks
    Last Post: 04-12-2016, 09:26 PM
  2. CAMworks adding unwanted tools to crib
    By DasNewb in forum CamWorks
    Last Post: 01-24-2016, 08:29 PM
  3. Replies: 0
    Last Post: 04-22-2015, 03:11 PM
  4. TURNING TOOLS!
    By didzbartholome in forum CNC Tooling
    Last Post: 09-21-2011, 11:21 AM
  5. Searching for a little CNC turning machine with powered tools
    By Simon1978 in forum Turning Machines
    Last Post: 02-04-2010, 06:55 PM
