585,969 active members*
4,354 visitors online*
    1992 Haas VF0
    I recently picked up this little Tupperware VF0 from a friends shop that was moving.
    Serial number is in the 1800’s, very early machine.
    Everything works after a couple adjustments and cleaning.
    7k spindle, rigid tap etc.
    This is mainly for my personal use. I have run haas machines for about 20years.
    Ran my first real part and found issues with my “y” axis.
    I interpolated a 7.13in diameter hole in a piece of aluminum.
    “X” was dead on 7.13 but “Y” measure 7.148. Approx .018 large.
    I still need to do a backlash test, and recently found that this machine has belt driven ball screws.
    Could this be from stretch?
    Thank you
    Ken
    Aug 2009
    1573
    Re: 1992 Haas VF0
    ...possible incorrect Backlash setting?
    Re: 1992 Haas VF0
    I will see if I can do backlash today. Hopefully it shows me something
    Ken
    Jul 2020
    7
    Re: 1992 Haas VF0
    Check thrust bearings, mechanical backlash with a dti, and runout on the screw, of course dont change any params without saving the original values, and go from there, good luck.
  1. 1992 VF2 Wieght
    By dafowfidy in forum Haas Mills
    Last Post: 02-13-2022, 02:03 PM
  2. 1992 Haas VF1 dirve 149 spindle turning error
    By srecord1 in forum Haas Mills
    Last Post: 10-24-2014, 08:58 PM
  3. 1992 Haas VF-2 High Power Ceramic Resistors
    By SadieD in forum Haas Mills
    Last Post: 03-28-2013, 10:06 AM
  4. 1992 Haas vf-2 this is insane...
    By mikemike^3 in forum Haas Mills
    Last Post: 01-05-2012, 03:15 AM
  5. Need 1992 Haas VF0 drive board ASAP!
    By jrudicel in forum CNC Machining Centers
    Last Post: 09-29-2007, 02:05 AM
