585,715 active members*
4,591 visitors online*
    Nov 2020
    SH-HC31 THC install
    I have recently replaced the THC on my CNC plasma table. The machine Chinese and uses the Start Shapon SH-2012AH controller. I purchased the table without the plasma operational and the original SH-HC30 THC had a damaged plug and is now obsolete, hence the upgraded HC31.
    So, I have wired in the new THC and it does not function correctly. It will cut, but will not automatically adjust its height and is not showing the 'auto' light illuminated. I don't think I am getting the manual/auto signal correct from the controller.
    Does anyone have experience with this setup?
    Cheers!
    KPB
    Nov 2020
    Re: SH-HC31 THC install
    I have now got my machine working. Turns out some settings on the Start Shaphon SH-2012 controller were not correct.
    If anyone needs help with this setup in the future, send me a message.
    Cheers!
    KPB
    Apr 2010
    Hello KPB, I am considering buying this SH-HC31 model, I ask you:
    1: does it work well on flame cut? THC? capacitive?
    2: does it work well in plasma with thc voltage divider?
    May 2016
    12
    Bonjour
    Moi aussi je viens d'acquerir une machine plasma avec Torch height control du type HC31 et le controlleur Start Shaphon. Quand j'essaye de couper qqe chose la torch touche la tole et la deplace, il me semble que la THC ne fonctionne pas ou n'est pas activée. Quelqu'un peut-il m'aider au moins pour activer la THC? Merci
    Aug 2017
    Hello All, Happy new year.
    Deos any one save how to turns out some settings on the Start Shaphon SH-2012 controller were not correct.for SH-HC30?
    Thanks.
    melon25
  1. Need Instruction Manual THC SH-HC31
    By QuadMedic in forum Machinery Manuals / Brochures
    Last Post: 05-11-2018, 04:02 PM
  2. V25 Install
    By nlh in forum BobCad-Cam
    Last Post: 03-13-2013, 04:43 AM
  3. Un-install & re-install changes Mach3
    By Beefy in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2012, 09:01 AM
  4. Install help
    By djmickyg in forum LinuxCNC (formerly EMC2)
    Last Post: 12-02-2007, 03:05 PM
