585,932 active members*
3,711 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Locking for Heidenhain rotary encoder.
    Hello ,
    I would like to buy a Heidenhain ROD 462.018 1024 / S.NR.3 709 545 B / L4 for my Maho 1600 , the original broke so I can 't use the tool changer. If anyone has one for sale in Europe let me know.
    Nov 2020
    12
    Re: Locking for Heidenhain rotary encoder.
    It is a simple 1024 ppr TTL encoder, may be stick non-original in there?
    Quote Originally Posted by usolutions View Post
    Thanks , will try.
  1. Manually adjustable locking rotary axis
    By cncbcncb in forum Wood Lathes / Mills
    Last Post: 12-26-2015, 01:42 PM
  2. Manually adjustable locking rotary axis
    By cncbcncb in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-25-2015, 06:20 AM
  3. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  4. Use of TTL rotary encoder instead of 11uA heidenhain
    By wahidbashir in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2010, 06:42 PM
  5. Heidenhain Encoder
    By Rupe in forum Uncategorised MetalWorking Machines
    Last Post: 12-09-2008, 10:04 AM
