535,560 active members*
4,226 visitors online*
IndustryArena Forum > CAD Software > ViaCad / Shark > Cant seem to stop my holes from snapping in the wrong direction.
Results 1 to 2 of 2
    Registered
    Jun 2013
    198
    This example is a small gusset that will bolt on through the front face. The front face angles downwards. I would like the counter bore hole to be perpendicular with the rear face of my part. So when I bolt the part on the bolts are straight into the face behind the part. But what happens is the hole, no matter what I do, snaps to the front face, and angles down. If I drill from the back, its straight and perpendicular but I cant counterbore.
    Hard to explain so I have attached two images one in solid and one in lines.
    I have tried all SharkCad hole settings. The "normal" is the only one that will actually drill a hole. The others do nothing.
    Anyone know how to resolve this? Even the two point hole setting does not work.
    Registered
    Jun 2013
    198
    Re: Cant seem to stop my holes from snapping in the wrong direction.
    After ages I found the solution. Use a 2 point hole. Its just VERY sensitive with the snaps.
    Attached Files Attached Files
  1. Homing in wrong direction
    By Paul714 in forum Mach Mill
    Last Post: 01-27-2019, 11:20 PM
  2. My homemade CNC router cant cut holes as it should? Anyone know what can be wrong??
    By kayakman in forum Uncategorised WoodWorking Machines
    Last Post: 02-25-2017, 01:54 AM
  3. Cut off spindle direction wrong
    By WOTDesigns in forum Mastercam
    Last Post: 02-15-2016, 04:17 PM
  4. Y AXIS WRONG DIRECTION
    By cncbeastmaster in forum Haas Mills
    Last Post: 11-24-2014, 05:21 PM
  5. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
