585,880 active members*
7,904 visitors online*
    Nov 2020
    Problems with power supply
    hi everbody,i'm new in this forum.
    i have build router wood carve 60inch(1,5m) 98inch(2,5m).
    using mach3 usb.
    i'm use nema23 2,2nm & tb6600,with ballscrew for X axis.nema23 for z axis tb6600.
    i powered both x&z using smps powersupply 24v 10a .source 220v.
    i'm run both x&z(with each tb600 set 2a for test),its run well.
    but when i change x axis set to 2,5a &z axis set 2a.my powersupply get smoke fried.
    anybody can explain, please i need help. thankyou
    Nov 2012
    1267
    Re: Problems with power supply
    It could be that your power supply was not of the best quality. Good power supplies don't usually emit smoke even when overloaded or shorted. Did the TB6600s survive?
  1. Fanuc 6T power supply problems
    By andyhu in forum Fanuc
    Last Post: 07-26-2011, 09:44 PM
  2. Power supply problems
    By Ark1 in forum CNC Machine Related Electronics
    Last Post: 12-12-2010, 08:39 PM
  3. VF1 Low Voltage Power Supply Problems.
    By Bruce_Mowbray in forum Haas Mills
    Last Post: 09-17-2010, 04:14 PM
  4. Boss 5 power supply problems
    By dynamotive in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2009, 06:49 PM
  5. Power Supply Problems
    By Grayling in forum CNC Machine Related Electronics
    Last Post: 08-05-2008, 01:18 AM
