585,894 active members*
4,041 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > What BT30 pull studs does a DM2800 use?
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Feb 2014
    9
    Re: What BT30 pull studs does a DM2800 use?
    Quote Originally Posted by MrMetric View Post
    If they are available then I’d never make them. So not crazy. It is interesting though. When I contacted RKS they said they didn’t have any! And that was at about the same time. Strange.
    Retention Knob Supply item 341-14, they had hundreds in stock as of August 2019 at $26.46ea
  2. #22
    Apr 2010
    24
    You don't need to tighten them to like 80 foot pounds or use red locktite (like some holders I bought). a dozen should do you. Money well spent.
  3. #23
    Jul 2010
    172
    Recommended torque on the pull studs is 25 to 35 ft/lbs. I use the lower number.
    I also put anti seize on the threads and face. Makes it real easy for switching them out later.
    I haven't counted lately but my tool cabinet has over 250 tool holders in it.
    At least 50 are dedicated to drill and another 50 to end mills.
    If my program calls for any common drill, I just grab it off the shelf, enter the offset and away it goes.
    I can switch up tooling and programs in less than ten minutes.
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
  4. #24
    Jun 2021
    4
    Good afternoon my friends, My name is fabio seabra alive in portugal, owner of a motorcycle shop and workshop, Mxcross.pt Portugal,
    I recently bought this machine DYNA MYTE 2800 for my workshop, would you like someone to help me get it working on cnc connected to pc, or if the easiest thing would be to convert to mach3 program?
    I would very much like you to help me please my friends,
    In Portugal there is very little knowledge
Page 2 of 2 12
  1. Need help shopping BT30 holders and studs
    By ATRepair in forum Haas Mills
    Last Post: 05-12-2018, 06:16 AM
  2. Pull studs
    By Scrambled1 in forum HURCO
    Last Post: 11-20-2016, 08:19 PM
  3. need custom BT30 pull studs made
    By acannell in forum RFQ (Request for Quote)
    Last Post: 01-20-2014, 06:44 PM
  4. Which CAT 40 pull studs?
    By sortafast in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2013, 05:28 PM
  5. What pull studs
    By zcases in forum Fadal
    Last Post: 11-03-2012, 10:54 PM
