585,977 active members*
4,235 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HL-1 Spindle drive fault 123 / Overheat NEED HELP
    Hello !
    We are having issues with our HL-1 / 1998
    We bought machine in august this year. We have not done a single good part on it, we solved multiple errors on the machine. since that, and the last and most important is left.
    At the moment we have two errors on the machine:
    Spindle motor overheat 254 (fan is working, motor cold), when we clear this error via parameter 274:14 next issue happens -> when we run a programm, and rpm are dropped fast Spindle drive fault 123 appears and spindle spins freely. (fans work)
    Re: HL-1 Spindle drive fault 123 / Overheat NEED HELP
    Nov 2020
    I think that thanks for the valuabe information and insights you have so provided here. Play soccar with my team now!
    FYI, problem was fixed.
    1) We sent Vector To germany, for refurbishment. 1200eur
    2) faulty WYE / DELTA unit
    all done
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. Spindle Drive Fault
    By bk1955 in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2010, 02:24 PM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. Error 10 overheat 350 operating switch fault
    By casco in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-17-2009, 01:28 AM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
