585,589 active members*
2,830 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > OKUMA MU400VA OSP-P200 MH Large and heavy tools
    Jul 2019
    Hello,
    Machine is intermittently dropping the same tool. I believe the tool would fall under the Large and heavy category. Does anyone know how to designate a tool as heavy on an Okuma P200 controller? the machine is listed below;
    Okuma
    MU400VA
    Controller OSP-P200 MH
    Your input is much appreciated
    Ray
    Jun 2015
    4154
    Re: OKUMA MU400VA OSP-P200 MH Large and heavy tools
    hy
    ... heavy atribute reduces arm swing speed
    ... large atribute checks for atc neighbour pots to be empty
    * thus, neither is related to spindle clamping
    does the weight of your toolholder+tool<maximum allowed for your machine ( values should be listed inside the operation&maintenance manual, and also inside machine catalogue ) ? if yes, then maybe :
    ... your spindle clamping power has reduced; broken elements maybe ?
    ... your toolholder does not make proper contact with the spindle taper
    ... pulstud needs to be replaced
    ... there is a lack of balance, even if rpm is low
    if i understood right, that the tool does drop/fly-off, i would recomand checking spindle's retention force, taper contact and claws condition ( those that grip the pullstud ) / kindly
    Dec 2008
    3109
    Quote Originally Posted by Raylawando9 View Post
    Hello,
    Okuma
    MU400VA
    Ray
    If you are dropping tools from the tool change arm.
    Then forget 99% of kitty's comment. It has nothing to do that involves the spindle, pullstud or taper.
    The only item that may assist is defining a Heavy tool.... but I'm not sure if it is a purchased option or not... yes it should slow the rotating speed of the tool arm.
    Check the tool change arm out fully, all things that grip the vee.
    ... if casting is split
    ... spring / grip pin assembly
    Apr 2006
    111
    Hello,
    Okuma
    MU400VA
    Ray
    Max 10kg
    Apr 2009
    1262
    Try SET 5,L when setting a large tool #5. That should slow it down. If adjacent tools need to be dummy, then use ,D. If clearing use * to remove setting. I think ,H may also work for heavy tool.
    Experience is what you get just after you needed it.
