584,861 active members*
4,996 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Y axis cuts inconsistant, progressively worse over course of job. Chinese Trocen cont
Results 1 to 9 of 9
    Question Y axis cuts inconsistant, progressively worse over course of job. Chinese Trocen cont
    Hello all!
    I am rather new to CNC's, but have spent the last few months obsessively reading and upgrading my 50w Trocen controlled chinese blue machine 500x300mm.
    The problem I am running into is that my machine is becoming very inaccurate along the y axis. when I cut a series of slots or holes moving down the y axis, the spacing becomes progressively inaccurate. as the job progresses, even the slots themselves do not end up where they began, as if the cutting head moves up less than it moved down. if I cut circular dials, the central holes become more and more off center. I have already spent a long time with laser alignment, and gantry squaring and it doesnt appear to be that. it is accurate at the beginning of a job, and becomes progressively worse, as if every time it tries to return to a given Y position it doesnt quite get there. I will attach some photos to show what I mean.(the photos are all rotated , not sure why. the gap in the circles is along the y axis) Raster engrave seems to work just fine, although there seem to be more pronounced ridges. Is this a stepper motor problem? thanks everyone.
    Dec 2013
    5717
    Re: Y axis cuts inconsistant, progressively worse over course of job. Chinese Trocen
    A slipping motor coupling or pulley perhaps?
    Jim Dawson
    Sandy, Oregon, USA
    Do you mean the belts? I have checked both y axis belts for same tension/enough tension. Can the pulleys themselves be slipping?
    Dec 2013
    5717
    Yes, it's possible for the pulleys to slip on the shafts. Sometimes they come loose.
    Jim Dawson
    Sandy, Oregon, USA
    I will check into that tonight, Thanks!
    Nov 2008
    644
    On Y axis I would grasp both pulleys on the ends of each axis and gently twist the shaft. Tighten anything that allows it to move.
    Also make sure the belt isn’t riding up on the pulley flange. Check that the belt tension doesn’t vary as the axis moves, which is unlikely unless something is bent.
    I pulled the entire gantry and y axis motor and shaft. you were right, there is considerable play in one of the gears. I am not sure how these are fit on, there does not seem to be any sort of notch or keyway.. I am not sure how I would find a replacement spline gear for this belt. any ideas? thank you again for the help, half way there!
    I can pull the spline about a mm off the shaft by hand, would you think it is simply press fit? the shaft itself is approx .3 in or 7.62mm, and covered in tiny ridges.
    Attached Thumbnails Attached Thumbnails 20201130_131949_compress75.jpg   20201130_131951_compress1.jpg   20201130_132525_compress3.jpg   20201130_132012_compress5.jpg
    I just got the spline off by pulling really hard there is some sort of grey dry stuff on the shaft, reminds me of graphite lubricant, but that doesnt make much sense. could I just locktite the spline on the shaft? I just need to fix it in place yes?
    Dec 2013
    5717
    For this application I think red Loctite will work. Not the best, and normally I would not recommend this for a fix. Maybe JB Weld would be worth a look also, should be right next to the Loctite on the store shelf.
    Jim Dawson
    Sandy, Oregon, USA
  1. material sensor (amplifier) for Trocen TF-6225
    By tloudev in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-05-2019, 11:03 AM
  2. RECI W1 Low power with Trocen
    By Gmasterrr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-27-2019, 10:01 PM
  3. Replies: 4
    Last Post: 03-11-2012, 12:14 AM
  4. Can a 15 Amp cont. driver work with a 19A cont. motor?
    By maquiza in forum Servo Motors / Drives
    Last Post: 09-17-2008, 09:44 PM
  5. Progressively milling to final size
    By davejpc in forum G-Code Programing
    Last Post: 11-08-2007, 11:38 AM
