585,974 active members*
4,213 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Help with erratic Z position after tool change.
    DIY router: My tool change position is Z2. During run when M6 is called tool moves to Z2. After tool change it should return to previous position. PROBLEM: Tool moves to Z~=1, DRO shows Z~=-14. Any ideas?
    Re: Help with erratic Z position after tool change.
    Quote Originally Posted by Glen1Cafferty View Post
    Not sure about DRO.
    But if it is CNC control, then we can set gear ratio by parameters to correct it.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Quote Originally Posted by cncmakers001 View Post
    Not sure about DRO.
    It is not consistent. All axis respond correctly when I run simple exercise code (+5' -5 loop). Not just with the tool change. Sometimes when jogging with a 1"increment, it will move only half the distance but the DRO says it moved about ten times that.
    J
  1. Park & tool change position after tool probe.
    By Ozzybee57 in forum Mach Mill
    Last Post: 10-16-2016, 03:57 PM
  2. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  3. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  4. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  5. change Z position of the spindle in tool change
    By michael-p in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2011, 09:18 PM
