584,866 active members*
4,982 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Gcode or Javascript center probe script
    Apr 2017
    77
    Hi
    Does anyone have a center hole finder script for use with my grbl controller?
    Mar 2015
    409
    Re: Gcode or Javascript center probe script
    You could probe in 2 directions and use the mean value of the to probe positions to find the center.
    Grbl can only execute the probe movement and report the position found.
    This task is normally done by the GUI. Grbl could be extended to do this
    A way of how it could be done at the moment: https://github.com/cncjs/cncjs/issues/301
    May 2004
    210
    You could try ioSender. It has center finding.
  1. probe script
    By edcross in forum Mach 4
    Last Post: 07-12-2020, 02:20 PM
  2. Find Center Error "Probe Ignore, Activated at call for probe"
    By ngr1 in forum Mach Wizards, Macros, & Addons
    Last Post: 02-23-2020, 05:46 AM
  3. Gcode for milling a hole from the center
    By Jibeji in forum G-Code Programing
    Last Post: 04-15-2018, 08:03 PM
  4. Replies: 15
    Last Post: 02-26-2018, 03:00 AM
  5. How to set up TS27R probe center?
    By technetics in forum Cincinnati CNC
    Last Post: 01-01-2013, 06:29 PM
