585,775 active members*
4,251 visitors online*
    Nov 2020
    Stepper grinding randomly
    Hi All - I know there are about 100 topics here regarding stepper grinding, but this one has me puzzled. I have a recently converted machine using Automation Technology KL-8056D drivers, KL-DB25 breakout board (parallel port), all running through Mach 3. I can get the motors running smoothly on the table, but they will suddenly start to act funny. I've tried messing around with the wires, that doesn't seem to do much. I'm not sure if it's a setting on the stepper driver, or an unstable parallel port. I put a ran a program on it to show how intermittent the problem is.
    https://youtu.be/b5CHwAnDChA
    Sep 2020
    81
    Re: Stepper grinding randomly
    looks like the signal is getting interrupted inbetween. I am no expert but are you running other process on the pc? This may cause interrupts.
  1. Stepper Grinding Noise and Getting Stuck
    By sor2020 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-21-2019, 06:03 PM
  2. Stepper motor grinding
    By Blendwood in forum Stepper Motors / Drives
    Last Post: 09-09-2017, 03:51 AM
  3. Replies: 1
    Last Post: 09-08-2017, 02:54 PM
  4. Stepper motor noise and grinding
    By motion86 in forum Stepper Motors / Drives
    Last Post: 01-23-2014, 10:31 AM
  5. Stepper Motor is switching directions randomly
    By Scoyle7832 in forum Stepper Motors / Drives
    Last Post: 03-05-2011, 05:13 PM
