585,997 active members*
5,010 visitors online*
    Jun 2013
    443
    Cheap and easy cnc mist fluid.
    I've been using water soluble lathe coolant fluid mist on my router for alloy. Its awesome, but I definitely do notice the difference when I dilute it too much.
    Wondering what other people use for a cost effective solution? I am thinking of making it a flush system as the mist is not recoverable and I have built the table that way.
    Looking around at options I am seeing most fluids are $100 to $250 for 5L
    What do you use?
    Oh. I did try Jet A1 once (kerosine) it worked ok too but was steenky and slightly scary.
    Sent from my SM-N970F using Tapatalk
    Apr 2007
    273
    Re: Cheap and easy cnc mist fluid.
    this mist coolant works well. i think it's around $45 for a gallon but it goes a long way since it's mixed with water. it has rust inhibitors as well.
    1 gallon will make 32 gallons of mist coolant.
    https://koolmist.com/formula-77-for-tougher-service
    Jun 2013
    443
    Thanks Machinedude.
  1. Cheap cutting fluid
    By ftkalcevic in forum Australia, New Zealand Club House
    Last Post: 05-06-2016, 08:01 AM
  2. SS 304 sheets milling dry or with fluid coolant mist
    By Vincent82 in forum MetalWork Discussion
    Last Post: 11-18-2007, 05:40 AM
  3. Mist oiler cutting fluid
    By balsaman in forum MetalWork Discussion
    Last Post: 11-05-2005, 04:01 AM
  4. Cheap & easy materials for CNC machine
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-19-2004, 02:39 AM
