You aren't answering questions so it makes it hard to have progress.
Which KFLOP axis is your Z axis? Does your Z axis work in KMotion.exe?
TK
http://dynomotion.com
I don't know why, but they are all working/counting correctly now. I couldn't get it last night, but it's working now. Freaking gremlins!
I'm trying to run G code to test axis movement and keep getting (Gcode error Gcode Aborted) seemes to happen on G0.
Most likely the Velocities and Accelerations in KFLOP are set too high.
TK
KMotion.exe used to set, test, and create the Init C Program control G0 Rapid rates. The settings are dependent on your system. See also here.
A common problem is to have too high of settings and not realize it when only testing small moves. This is like stating your car can go 300mph but then only test it in your driveway.
TK
Hi Gunmachinist,
Please put more effort into your responses otherwise we don't know what you are doing and can't help.
Please determine your Velocities, Accelerations, and Jerks as described here. Describe what you did and post the results. Test big enough moves that reach full velocity and post them.
TK
I have read and reread Dynomotion wiki. I have re-tuned the servos and after tuning I decreased Velocity, and Acceleration by 20% and updated my C program. X and Y axis are at 40000 Velocity and 400000 Acceleration, Z is 32000, and 320000. Jerk is set at 100000 for all three axes. I entered the information in Kmotion CNC for XYZ axis and attempted to run a short program just to verify that the axis would work, and I get the message Gcode error/Gcode aborted. I've tried different G code programs with the same results. At this point I dont know what more to include, It may help if you guys would ask questions.
Here is C code as it is now.
#include "KMotionDef.h"
// Default Initial Configuration for 3 Axis Analog DAC Servo with encoder feedback
// Note Low Gains, Limited Max Limits, No Limit Options, No Soft Limits,
// Large allowed Following Error, No Feed Forward, No Filters, etc
void main()
SetBit(152); // enable AMPS
SetBit(157);
SetBit(158);
ch0->InputMode=ENCODER_MODE;
ch0->OutputMode=DAC_SERVO_MODE;
ch0->Vel=32000;
ch0->Accel=320000;
ch0->Jerk=100000;
ch0->P=26.68;
ch0->I=0.0001;
ch0->D=32.332;
ch0->FFAccel=0.0001;
ch0->FFVel=0.0009;
ch0->MaxI=2047;
ch0->MaxErr=100;
ch0->MaxOutput=2047;
ch0->DeadBandGain=3;
ch0->DeadBandRange=0;
ch0->InputChan0=0;
ch0->InputChan1=1;
ch0->OutputChan0=0;
ch0->OutputChan1=1;
ch0->MasterAxis=-1;
ch0->LimitSwitchOptions=0x11f;
ch0->LimitSwitchNegBit=136;
ch0->LimitSwitchPosBit=136;
ch0->SoftLimitPos=1e+30;
ch0->SoftLimitNeg=-1e+30;
ch0->InputGain0=1;
ch0->InputGain1=1;
ch0->InputOffset0=0;
ch0->InputOffset1=0;
ch0->OutputGain=1;
ch0->OutputOffset=0;
ch0->SlaveGain=1;
ch0->BacklashMode=BACKLASH_OFF;
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
ch0->invDistPerCycle=1;
ch0->Lead=0;
ch0->MaxFollowingError=10000000;
ch0->StepperAmplitude=250;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch0->iir[2].B0=1;
ch0->iir[2].B1=0;
ch0->iir[2].B2=0;
ch0->iir[2].A1=0;
ch0->iir[2].A2=0;
ch1->InputMode=ENCODER_MODE;
ch1->OutputMode=DAC_SERVO_MODE;
ch1->Vel=40000;
ch1->Accel=400000;
ch1->Jerk=100000;
ch1->P=22;
ch1->I=0.0001;
ch1->D=12;
ch1->FFAccel=0.0001;
ch1->FFVel=0.0006;
ch1->MaxI=2047;
ch1->MaxErr=100;
ch1->MaxOutput=2047;
ch1->DeadBandGain=4;
ch1->DeadBandRange=0;
ch1->InputChan0=1;
ch1->InputChan1=1;
ch1->OutputChan0=1;
ch1->OutputChan1=1;
ch1->MasterAxis=-1;
ch1->LimitSwitchOptions=0x11f;
ch1->LimitSwitchNegBit=138;
ch1->LimitSwitchPosBit=138;
ch1->SoftLimitPos=1e+09;
ch1->SoftLimitNeg=-1e+09;
ch1->InputGain0=1;
ch1->InputGain1=1;
ch1->InputOffset0=0;
ch1->InputOffset1=0;
ch1->OutputGain=1;
ch1->OutputOffset=0;
ch1->SlaveGain=0;
ch1->BacklashMode=BACKLASH_OFF;
ch1->BacklashAmount=0;
ch1->BacklashRate=0;
ch1->invDistPerCycle=1;
ch1->Lead=0;
ch1->MaxFollowingError=10000000;
ch1->StepperAmplitude=250;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=1;
ch1->iir[2].B1=0;
ch1->iir[2].B2=0;
ch1->iir[2].A1=0;
ch1->iir[2].A2=0;
ch2->InputMode=ENCODER_MODE;
ch2->OutputMode=DAC_SERVO_MODE;
ch2->Vel=40000;
ch2->Accel=400000;
ch2->Jerk=100000;
ch2->P=6;
ch2->I=0.0001;
ch2->D=6;
ch2->FFAccel=0.0001;
ch2->FFVel=0.0009;
ch2->MaxI=2047;
ch2->MaxErr=1000;
ch2->MaxOutput=2047;
ch2->DeadBandGain=3;
ch2->DeadBandRange=0;
ch2->InputChan0=2;
ch2->InputChan1=1;
ch2->OutputChan0=2;
ch2->OutputChan1=1;
ch2->MasterAxis=-1;
ch2->LimitSwitchOptions=0x11f;
ch2->LimitSwitchNegBit=137;
ch2->LimitSwitchPosBit=137;
ch2->SoftLimitPos=1e+30;
ch2->SoftLimitNeg=-1e+30;
ch2->InputGain0=1;
ch2->InputGain1=1;
ch2->InputOffset0=0;
ch2->InputOffset1=0;
ch2->OutputGain=1;
ch2->OutputOffset=0;
ch2->SlaveGain=1;
ch2->BacklashMode=BACKLASH_OFF;
ch2->BacklashAmount=0;
ch2->BacklashRate=0;
ch2->invDistPerCycle=1;
ch2->Lead=0;
ch2->MaxFollowingError=10000000;
ch2->StepperAmplitude=250;
ch2->iir[0].B0=1;
ch2->iir[0].B1=0;
ch2->iir[0].B2=0;
ch2->iir[0].A1=0;
ch2->iir[0].A2=0;
ch2->iir[1].B0=1;
ch2->iir[1].B1=0;
ch2->iir[1].B2=0;
ch2->iir[1].A1=0;
ch2->iir[1].A2=0;
ch2->iir[2].B0=1;
ch2->iir[2].B1=0;
ch2->iir[2].B2=0;
ch2->iir[2].A1=0;
ch2->iir[2].A2=0;
EnableAxis(0);
EnableAxis(1);
EnableAxis(2);
DefineCoordSystem(2,1,0,-1);// define XYZA axes
Actually I see now the Following Errors are set huge so regardless of how bad the tuning is you wouldn't get any error. It must be something unrelated to tuning.
I see "Launch on Power up" is set so you have modified KFLOP. Please remove those changes by re-flashing "New Version"
I can't think of why you would get a "G Code Error" without some other message. Is there any? You might try simulating the GCode.
Maybe the installation is messed up. You might reinstall it after making a copy of your current installation.
TK
huh?also.
Configuration ScreenThe max following errors in the configuration or step response screen?
And?I reflashed
Yes, but actually the full installation on the PCI assume your talkning about KMotion and KMotion CNC?
TK
Observe what your following errors are under normal conditions and set to a larger value.I'm working on the Max following errors to get them down. When I started it basically stopped the axis from working. How low should the Max following error be?
TK
I did some work with tuning my axis and have been able to get the Max Following Errors down, but when trying to run G-code I still get and the same error code. Here is my current screen shots of each axis. I ve also been playing with TripsWPF, and could you explain how I'm supposed to use the check all?
It seems you miss-understood my post #31 where I tried to explain following error was not the problem and to try other things. So then you focused on following error and ignored the other suggestions.
Its good your playing with TripsWPF. Hopefully you get a better understanding of Velocity, Acceleration, Jerk, and distance.
Regarding TripsWPF Check All button: You wouldn't use it. Its for our use to apply many sets of parameters to TripsWPF to check it is able to solve them all correctly.
TK
Ok, Max following error, and tuning were my last resort after I reflashed and reinstalled KMotion. Those were the only things you mentioned so I tried all of them. If tuning isn't the problem with why im getting the G-code error then then Im guessing it's in setting up KMotionCNC trajectory planner. Do you see anything wrong in trajectory planner in post 30? What else could be the reason all I get is gcode aborted message?
Oops
I guess I dont know what I'm looking for with Trips, because it is not giving me good results when entering the information in KMotion. When getting settings in Trips what am I supposed to be looking for, do you have an example of what a good looking Trips looks like?
