585,954 active members*
4,182 visitors online*
    Feb 2019
    13
    Angry need help - zeroing material xy
    when i zero my x&y to material i have to use outside edge of tool instead of center of tool. is their a setting some where to change. What happens when i zero on center of tool it cuts half the diameter to the right. pats come out correct size just wrong place on material. I Use mach3&vectric aspire.
    Apr 2004
    5737
    Re: need help - zeroing material xy
    When zeroing with a tool to the edge of your stock, you need to compensate for the radius of the tool. So, for instance, if you were using a half-inch tool touched off to the edge, you'd add a quarter inch if it was on the negative side, or subtract it if it was on the positive side. If your controller doesn't let you put in any value but zero, move the tool up to clear the stock and a quarter-inch over to the edge, then press the zero button. Usually it's recommended to do this with an edge-finder instead of the actual tool, to avoid damage to the tool and/or the stock.
    Andrew Werby
    Website
    Feb 2019
    13
    thanks, for your answer.
    Feb 2019
    13
    Thank You AWERBY for your answer it got me going in the right direction. i purchased 2010 screen set and it simplified everything. thanks again
  1. Replies: 0
    Last Post: 10-21-2018, 05:01 PM
  2. Zeroing a tool
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 06-11-2016, 11:55 PM
  3. KMotion CNC Keeps ZEROING!
    By Elocremarc in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-24-2016, 01:09 AM
  4. zeroing problem
    By yasser72 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2015, 03:38 PM
  5. Zeroing Precisely
    By LenMcC in forum Torchmate
    Last Post: 07-21-2008, 05:34 PM
