584,861 active members*
4,731 visitors online*
Results 1 to 7 of 7
    Router causes jerky movements
    When running my DIY CNC Router, everything seems to run OK, until I turn on the Router. Then movements are jerky. For example: Code says G0 X10 Y6, but machine makes several short movements to go there. Position seems correct at end of movement. I was thinking electrical noise. I moved router power to a different circuit and frequency of interruptions went down but are still there .After I started thread, I found that the USB connection was intermittent, but changing cables did nothing. Is my problem more likely Electrical noise, or vibration shaking a connection on the board lose?
    Apr 2004
    5728
    Re: Router causes jerky movements
    Is the spindle of your machine a 3-phase motor run by a VFD, or a regular hand router? Have you solved the problem of the intermittent USB signal?
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    It's a compact router. Not found location of intermittent connection. Wiggling the USB cord connection doesn't cause the problem.
    Quote Originally Posted by Glen1Cafferty View Post
    With my hearing aids on, I can hear the PC's USB disconnect tone when the movement pauses.
    The spindle is a DeWalt compact router. The CNC runs properly through the entire code. When I turn on the router the USB connection cuts out. The light on the interface board goes out and I hear the disconnect tone from the PC. Wiggling the USB cable makes no difference. Any suggestions?
    15362
    Is the USB cable Shielded with ferrites on each end, this can help, for a test you could shield it with some tin foil
    Does your router have a Ground or is it an isolated connection with a 2 pin / blade plug
    Mactec54
    Apr 2004
    5728
    It sounds like you've solved your problem, then, or at least isolated it. Just replace whatever your controller is using to connect to the USB port,
    Andrew Werby
    Website
  1. CNC Router Super Jerky
    By dameronw in forum Mach Software (ArtSoft software)
    Last Post: 06-03-2017, 03:10 PM
  2. Axis movements are jerky
    By Terrible Terry in forum Fadal
    Last Post: 11-21-2016, 04:31 AM
  3. Erratic movements, inconsistent action. uncontrolled movements
    By dusty41 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-06-2014, 11:36 AM
  4. jerky movements arrow 750
    By chaz6966 in forum Cincinnati CNC
    Last Post: 02-17-2009, 04:41 PM
  5. Bridges & jerky movements.
    By Moondog in forum Machines running Mach Software
    Last Post: 07-30-2006, 04:28 AM
