585,992 active members*
5,878 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > .010" egg-shaped while circle milling.
    Nov 2013
    402
    Yikes!!
    I was circle-milling some bores yesterday, and they were coming out .010" egg-shaped.
    Y axis seems ok, as the bore was on size, but in X, I was getting +.010"
    Would this be a backlash issue? Or is it loose Gibs?
    Looks like it's time to tear the mill apart and tighten everything up.
    Nov 2012
    591
    Re: .010" egg-shaped while circle milling.
    It could be loose gibs on Y, or backlash on X, or even perhaps some slop in the head/spindle. Sure hope it isn't the last one!
    Aug 2009
    1573
    ...is frontlash possible? (wedge) Newton's Law of motice
    https://en.wikipedia.org/wiki/Newton%27s_laws_of_motion
    Aug 2010
    130
    What material and size and how were you holding it? I've seen egging like that in plastic parts held in a vise. The vise was compounding a little bit of out-of-round. If there is any flex in the piece that could be contributing to seeing something egged more than expected, even in metals.
    Do you see the same amount on different size holes?
  1. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  2. milling with shaped tools
    By choppero in forum SprutCAM
    Last Post: 09-15-2013, 04:38 AM
  3. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  4. "Fill circle" engrave function LaserCut 5.1
    By grzegorz1965 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-03-2008, 01:04 AM
