585,758 active members*
4,222 visitors online*
Results 1 to 7 of 7
    Jan 2020
    10
    Avid CNC tripping breakers?
    Looking for some guidance on where to get started. My 4'x2" avid cnc table with nema 34 plug and play electronics lost power while running. It tripped a few breakers as I troubleshot. Is something shorted out? It trips immediately when plugging in. Thanks!
    Dec 2013
    5717
    Re: Avid CNC tripping breakers?
    A short would be my best guess.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1570
    ...which ones have Tripped? Spindle Drive most like
    Jan 2020
    10
    The entire machine is down. Any tips on figuring out a possible short issue?
    Dec 2013
    5717
    It's most likely something simple, maybe the power cord input going to ground or something. You are just going to have to look at the wiring.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by jamesfiore View Post
    Post some photos of the wiring we may be able to see something, you say " Breakers" there should only be one main Breaker for your main input power supply to your machine, need some photos to see what you have
    It could be a faulty Power supply or your plug cable connections at the spindle
    Mactec54
    24220
    If you have any fusing or other kind of disconnect means on different parts of the machine, try only allowing different sections to initially power up and see it it can be isolated to one power item/device.
    Al.
    Albert E.
  1. sl150y machine shutting down, tripping breakers
    By mikeminok in forum Mori Seiki lathes
    Last Post: 04-22-2021, 12:50 AM
  2. hydraulic breakers & attachments
    By zppark in forum News Announcements
    Last Post: 12-30-2018, 06:42 AM
  3. Protection - where to put fuses and breakers
    By bobmagnuson in forum CNC Machine Related Electronics
    Last Post: 11-07-2014, 10:42 AM
  4. circuit breakers
    By JamesKain in forum Maintenance DIY Discussion
    Last Post: 12-26-2012, 03:49 PM
  5. To use breakers or not?
    By cambridgecnc in forum Controller & Computer Solutions
    Last Post: 05-26-2010, 07:06 PM
