585,717 active members*
3,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, is it possible to superimpose dual spindle, single turret lathes ?
Results 1 to 6 of 6
    Jun 2015
    4154
    hello please, is it possible to superimpose 2s+t lathes ? like when drilling, or turning same id/od on both spindles ?
    or is there a ' trick ' ? kindly
    Apr 2006
    822
    Re: pls, is it possible to superimpose dual spindle, single turret lathes ?
    Please, what is it you are trying to achieve?
    Maybe I could help?
    Jun 2015
    4154
    hy broby such a lathe should arrive soon ( ± ), and there is a simple, repetitive job, that will be moved to it
    part is almost simetrical, now being faced + od + half id + cut, then flipped in order machine the other id half
    i was thinking if it would be possible to machine, simultaneously, both id halfves / kindly
    Apr 2006
    822
    Can you supply a drawing?
    Jun 2015
    4154
    hy broby, is a simple one : od 55±0.2 x id 37.5+0.2 x length 145±0.5, machined from a pipe od 56 x id 35 do you still wish for a drawing, or anything else, like tools, other details ? thank you
    Jun 2015
    4154
    hello all i solved this 9 months ago
    such a function is more used in the gang lathes enviroment, while okuma is missing a 2nd linear axis on the 2nd spindle, so this results in some limitations
    even so, it works flawless for common simple parts, thus the extra mobility of a gang may not be required
    please feel free to ask anything / kindly
  1. Are Twin spindle Twin turret lathes as complex as they look?
    By vfsi in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2019, 08:39 AM
  2. Replies: 0
    Last Post: 03-27-2018, 06:42 PM
  3. Okuma dual turret lathes
    By kawman in forum BobCad-Cam
    Last Post: 04-23-2014, 07:02 PM
  4. Single Phase cnc lathes and mills
    By rbkelso in forum MetalWork Discussion
    Last Post: 11-14-2007, 05:19 PM
  5. Single Phase cnc lathes and mills
    Last Post: 09-23-2007, 02:10 PM
