585,748 active members*
3,513 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > Electronics > Trouble connecting AXBB-E out puts to relay board
    Dec 2007
    341
    Hi every one i need a little help with connecting this relay board for outputs, i am not sure if the outputs is a negative coming from the board, output providing ground to complete circuit or something else ,just do not want to let the smoke out.
    I have provided the boards manual and the relay board schematic any help would be greatly appreciated . Attachment 453244
    Dec 2007
    341
    Re: Trouble connecting AXBB-E out puts to relay board
    Problem resolved ,i had to put a 1K resistor in line for each out put for the board.
    Dec 2020
    8
    To potentially save me a few weeks how exactly did you wire it?
    I can get the led lights on the board to light up but I can not get It configured with Mach 3?
    Dec 2020
    8
    If it helps anyone else, just wire it as per manual and you set mach3 Ports and pins to Eg;
    port 2 pin1 (not 11 or I1)
  1. 6040 with AXBB controller problem connecting VFD
    By alkis01 in forum Chinese Machines
    Last Post: 11-26-2023, 01:33 AM
  2. my AXBB-E and UCSB are on the way, small annoyance is anyone using axbb with mach3?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 05-17-2019, 03:50 AM
  3. New AXBB Motion Controller and Breakout Board Now Available
    By arturod in forum News Announcements
    Last Post: 04-09-2019, 04:53 AM
  4. need help connecting breakout board to relay to vfd
    By daniellyall in forum Phase Converters
    Last Post: 04-20-2012, 04:33 AM
  5. Help connecting an AC Relay.
    By Rene Nuñez Paz in forum DIY CNC Router Table Machines
    Last Post: 10-01-2011, 05:02 PM
