585,975 active members*
4,674 visitors online*
Page 1 of 2 12
Results 1 to 20 of 38
    Jan 2007
    19
    Smile My little project
    I've been making lots of progress lately and decided that the time has come to share my results with the forum that's been a great help to me along the way.
    My research and parts gathering began in December of '06, but I didn't actually start the build until June 25, 2007.
    My gantry is supported and driven from one end and there is some flex I'm working to eliminate. I haven't made the slats yet, but in the meantime, it does work! The little wrench was cut from 10ga. with a standard nozzle, wirebrushed and painted.
    Attached Thumbnails Attached Thumbnails basic table.jpg   table detail.jpg   power supply.jpg   power supply detail.jpg
    Apr 2005
    81
    Hey Pyrotechncal,
    Looks great so far. Are you following any drawings if so could you share them?
    Also do you plan to paint it?
    What kind of plasma cutter are you using? Sorry for all the questions but Im getting ready to build my own table.
    Vince
    Oct 2005
    1238
    Arrow Great Work
    Quote Originally Posted by Pyrotechnical View Post
    Very nice construction work on your project!
    You certainly have been busy the last few weeks, and the research shows wonderful results.
    Thanks for sharing the fine photos of your great work.
    Jan 2007
    19
    Thanks for the kind words. Yes, I have been busy.
    I'm using a Hypertherm 1000, and recommend it highly. I'm sure there are other models that would be good too, but on upgrading from a Hypertherm 600, the 1000 is worth double the price difference between the two.
    Paint will be applied after I've finished construction and modifications.
    I'm not working from plans of any sort, but rather figuring things out as I go. If you're curious about any specific dimensions don't hesitate to ask.
    May 2007
    100
    Looks great. Thats a clean cut too.
    Jan 2006
    481
    hi
    Pyrotechnical very nice machine , keep up the good work.
    What motherboard are you using ? can not work it out from the pictures. I'm assuming you have height control ? on the Z-axis or are you setting this parameter manually for the different thickness of metal being cut.
    cheers
    Jan 2007
    19
    I'm not sure what you mean by "motherboard." The breakout board is a C10.
    No automatic THC at this time.
    May 2007
    250
    Cool Plasma machine
    Hi Pyrotechnical,
    It's a great project. You use manual or machine system for hypertherm 1000
    Is it possible to share the wiring diagram of hyperthem1000 with parallel port.? How to connect? I am going to build plasma machine same as you.
    Cheers,
    Mongkol
    Jan 2007
    19
    Quote Originally Posted by Mongkol View Post
    I'm not sure what you are asking. The torch is a manual torch.
    Are you asking how the plasma cutter is turned on and off? I ran an output from the breakout board to a switching transistor that activates a relay that is connected to the plasma cutter. The Hypertherm 1000 has inputs for remote start, but according to the manual they are inactive if a manual torch is connected. I'm sure there's a way around that, but in the interest of expediency I spliced into the same wiring that the manual torch switch uses.
    Jun 2006
    Will you share you motor/gear/rack combonation and source?
    May 2007
    250
    Smile Plasma machine
    [QUOTE=Pyrotechnical;326227]I'm not sure what you are asking. The torch is a manual torch.
    I am not sure.I refer from http://www.hypertherm.com/languages/...h/products.php. They shows both mechanized and manual torch.for powermax1000.
    Yes,I am little puzzled with turn on and off system. What port and pin of DB-25 can turn on or off the torch of plasma? if I use mach3:withstupi
    Cheers,
    Mongkol
    Jun 2007
    57
    hey, nice table.
    how is it working with the direct drive? no vibration, get enough torque? i see the motors are not big
    nice welding too
    Apr 2005
    81
    If you have made up dimensions for your setup, I would love to have them.
    thanks
    Vince
    Jan 2007
    19
    They shows both mechanized and manual torch for powermax1000.
    The torch pictured is the 90* manual torch. The mechanized torch is straight and has a rack gear mounted on it.
    I have Ports and Pins/Output Signals/Output 1 in Mach3 set to pin #17.
    Jan 2007
    19
    Quote Originally Posted by bekx View Post
    The rack and pinion drive works really well. The motors are 600 oz.in. and seem to have plenty of power.
    Jan 2007
    19
    Quote Originally Posted by vcooney View Post
    thanks
    Vince
    The outside dimensions of the table as seen in the first picture are: 108"L x 60"W x 30"H.
    • Legs: 2"x2"x0.120"
    • Side and End Rails: 2"x3"x0.120"
    • Leg braces: 2.25"x0.25"
    • X, Y, and Z bearing rails: 3/8"x2" cold rolled
    Mar 2006
    759
    I'm digging it, Pyro. Work looks good!
    Parts look great, too!
    Thanks for sharing your machine with us.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    May 2007
    250
    Plasma machine
    I just know. Thanks so much
    Port1#Pin17, This pin can also turn on or off spindle or not.
    Hi Pyrotechnical,
    Please help if you have a wiring diagram. Please have a look for my question.
    Here 's the first time for plasma table.:stickpoke
    Thanks so much
    Mongkol
    Attached Files Attached Files
    Jan 2007
    19
    I'm sure there are other ways of doing this, but here is what I did:
    May 2007
    250
    Plasma machine
    Hi Pyrotechnical,
    Thanksss... so much..
    I am little puzzled with pin17, Can it also turn on or off spindle?
    M03 and M05 commands in g-code can control pin17. It's right or wrong?
    In Hypertherm 1000, Wire in transistor connector.
    Purple wire. what does it mean?
    Orange wire. what does it mean?
    I search on datasheet in google. It doesn't show the detail.
    Cheers,
    Mongkol
Page 1 of 2 12
  1. New Project
    By Eric Brassard in forum Hobby Discussion
    Last Post: 08-30-2007, 12:05 PM
  2. Another New project
    By miljnor in forum Vertical Mill, Lathe Project Log
    Last Post: 02-15-2006, 06:21 PM
  3. My CNC project
    By eitanwaks in forum CNC Wood Router Project Log
    Last Post: 01-03-2006, 03:02 PM
  4. Look what I can do! (First CNC Project)
    By cp8071 in forum DIY CNC Router Table Machines
    Last Post: 09-06-2005, 10:26 PM
  5. Need a project
    By DDM in forum Community Club House
    Last Post: 08-27-2004, 06:05 AM
