585,996 active members*
4,005 visitors online*
Results 1 to 8 of 8
    Dec 2020
    Updating CNC from Windows 7 to Windows 10
    Hello,
    New to the forum here. Currently experiencing issues with updating my MachMation X15-110 from Windows 7 OS to Windows 10. Up to date on all windows 7 service packs, but when I go to install windows 10 it says “The language or edition of the version of Windows currently installed on your computer isn’t compatible by this tool”. Anybody have any experience or work-arounds with this?
    Nov 2013
    4372
    Re: Updating CNC from Windows 7 to Windows 10
    what external motion controller are you going to use?.
    Windows 10 is a 64 bit OS and therefore precludes the use of a parallel port, you must use an external controller like an Ethernet SmoothStepper
    or a UC300.
    Craig
    15362
    or a UC300.
    Craig
    Windows 10 can be installed as 32Bit or 64Bit
    He is using MachMotion control, he does not need any external controller
    Mactec54
    15362
    Quote Originally Posted by greygies View Post
    Hello,
    You would be best to contact MachMotion as they have a different software requirement
    Mactec54
    Nov 2013
    4372
    While Windows 10 can be installed as a 32 bit OS Machs parallel port refuses to work with it.
    If you want to use a parallel port then 32 bit Windows 7 or 32 bit XP is required.
    The original MachMotion kits were based on a parallel port. Whether later kits had external controllers or not I don't know.
    Craig
    15362
    Craig
    They have always had there own control
    MachMotion uses Ethernet and EtherCat
    Who would be using a parallel today, it is not required to run Mach3 they have long been gone
    Mactec54
    Hello,
    Why not use NC based controller, it is more simple more professional and no any virus.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    15362
    Quote Originally Posted by cncmakers001 View Post
    MachMotion is a cnc controller there are many that use windows base or Linux as an operating system, which is perfectly fine to use, there is no chance of a virus unless you the user infect it
    A NC based controller is not immune from being corrupted
    Mactec54
