585,930 active members*
3,568 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Importing geometry into solidworks-why can't I select an end face as a boss extrude?!
    Mar 2006
    42
    Importing a "Solidworks" file supplied by a manufacture. It's a linear rail assembly, I'm importing the rail.
    Simple, simple stuff here. I have a short section of rail modeled in whatever they modeled it in, and it was exported as a "*.SLDPRT".
    Solidworks opens the file, says "Hey, let's run featureworks and get this straightened out!" and proceeds to recognize features in the absolute dumbest way possible. Dumbest way possible, but the features are dimensionally accurate.
    I want it to pick up the end profile, and extrude that end profile along the length of the rail. Then, drop the screw holes and counterbores from the top face of the resulting solid. This would make sense, as the entire design of the rail is contained in this end profile. A single sketch, extruded along the length, would give the whole rail in any length you need. Then linear pattern the screw holes.
    Featureworks decides that the best way to model this is draw a rectangular base, extrude upwards to the top face, then chamfer and fillet away the profile. This leaves a model that can't quickly be adjusted for different lengths of linear rail. It also has dozens of features that could be obviated away in a single sketch.
    How do I get Featureworks to import this thing the way I want? The interactive checkbox throws errors regardless of any selection I make when I try to run the interactive mode.
    Apr 2018
    20
    Re: Importing geometry into solidworks-why can't I select an end face as a boss extru
    Hi switch.
    Have you found an answer to this challenge? Are you using Solidworks and if so what version?
    I have experienced something similar when working with 8020 Aluminum Extrusion profiles.
    vic
    Apr 2013
    6
    Quote Originally Posted by switch2472 View Post
    Post the file or a link where we can download it and take a look
    Mar 2008
    683
    I have NEVER had good results with feature works. Turn it off. You shouldn't need to use feature works just to extrude an existing face. Just use your "Move Face" command to offset or translate it. Or... Create a sketch and project the edges and extrude that.
    Mar 2006
    42
    Sorry for not updating this thread-I ended up just robbing the face geometry and creating a new file.
    The original file is available through Hiwin, I just emailed and asked for a solidworks model of the HG25 rail system.
  1. Replies: 3
    Last Post: 03-07-2014, 06:26 PM
  2. How to select geometry from 3d model
    By tome9999 in forum BobCad-Cam
    Last Post: 04-11-2011, 05:36 AM
  3. Can't select geometry?
    By phoodieman in forum Mastercam
    Last Post: 02-08-2010, 01:52 PM
  4. How to Select overlaping geometry
    By nfrees114 in forum BobCad-Cam
    Last Post: 07-23-2009, 10:07 PM
  5. bobcad v21 geometry won't select correctly
    By gromit68 in forum BobCad-Cam
    Last Post: 06-04-2008, 03:48 PM
