585,758 active members*
4,316 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons > ATC and Tool length sensor; While is Moving () is skipped; Emergency mode
Results 1 to 6 of 6
    Question ATC and Tool length sensor; While is Moving () is skipped; Emergency mode
    Good evening everyone,
    As already heard in the title, I have a problem with my self-written ATC (automatic tool change) and the combined tool lengths measured.
    There are 2 problems:
    1. The While Is Moving command is skipped in my opinion.
    That means if the machine, for example, the old tool snaps into the holder in y,
    it opens the spindle before it has reached the end point.
    2. When I test the ATC without a tool (otherwise it always falls out), the old tool still engages and as soon as it lifts in Z,
    it moves a few mm and then triggers the emergency stop switch.
    This also happens when the machine is miles away from the limit switches. The soft limit was deactivated for every test.
    I noticed that while I was looking at the input signals of all limit switches and reference switches on the diagnosis side,
    they were all briefly activated at the same time as the emergency stop signal.
    I have already checked all cables and connections, I hope you can help me.
    I also attach the ATC code.
    Code:
    'ToolChange Macro für Bettgestützte Wechsler 12/2020 HolzCNC-3D
    Sub Main()
    OldTool = GetCurrentTool() 'Tool in Spindel DRO, Mann muss das zum Einstellbildschirm hinzufügen
    x = GetToolChangeStart( 0 )
    y = GetToolChangeStart( 1 )
    z = GetToolChangeStart( 2 )
    a = GetToolChangeStart( 3 )
    b = GetToolChangeStart( 4 )
    c = GetToolChangeStart( 5 )
    tool = GetSelectedTool()
    NewTool = tool
    'Tool Change Macro (Bettgestützte)
    MaxToolNum = 8			'Maximale Werkzeuganzahl im Wechsler
    ToolDown   = -150.0		'Z Pos. zum greifen oder lösen des WKZs
    ToolUp     = -10.0		'Z Höhe um sicher über den Werkzeugen und Wechsler zu verfahren
    ToolDown2  = -120.0   'Z Höhe Zeite sicherheits höhe kurz vorher
    ToolVor    = -20        'Y position eingerasteter zustand Achtung muss Identisch mit Case Tabelle sein
    ToolBack   = -40.0      'Y position vorpositionieren
    Feed       = 500        'Forschub zum ein und ausrasten und zum spindel andocken
    'Werkzeug länge vermessen Macro
    Schalter   = 30         'Höhe des werkzeuglängen sensors
    XSchalter  = -800		'x position des Schalters
    YSchalter  = -20		'y position des schalters
    ZVorpos    = -200 		'z position bis zu der im Eilgang verfahren wird
    If NewTool = OldTool Then
           Exit Sub
    End If
    'Neues Werkzeug ist 0 also Spindel wird leer
    If NewTool = 0 Then
    'Schutz öffnen
    ActivateSignal(Output7) 'Einschalten des Druckluft Ventiels zum öffnen des Schutzes
    Code "G4 P2"			'Warte zwei Sekunde
    'Auf sichere Position fahren
    Code "G00 G53 Z" & ToolUp
    While IsMoving()
    Wend
    Code "G00 G53 A0"
    While IsMoving()
    Wend
    'Fahre Leerplatz vom alten Werkzeug an
    Call MovePos(OldTool)
    While IsMoving()
    Wend
    'Fahre vor den Halter
    Code "G53 Y" & ToolBack
    While IsMoving()
    Wend
    'Z Absenken vor dem Halter
    Code "G53 Z" & ToolDown
    While IsMoving()
    Wend
    'Werkzeug langsam einrasten
    Code "G01 G53 F" & Feed & "Y" & ToolVor
    While IsMoving()
    Wend
    'Werkzeug Spanner öffnen
    ActivateSignal(Output9) 'Einschalten des Druckluft Ventiels zum lösen des Werkzeugs
    Code "G4 P2.0"			'Warte zwei Sekunde
    'Leere Spindel nach oben Fahren
    Code "G01 G53 F" & Feed & "Z" & ToolDown2
    While IsMoving()
    Wend
    'Werkzeug Spanner Schliesen
    DeActivateSignal(Output9) 'Auschalten des Druckluft Ventiels zum spannen des Werkzeugs
    Code "G4 P1.0"          'Warte zwei Sekunde
    'Leere Spindel Ganz nach oben Fahren
    While IsMoving()
    Wend
    'Schutz schliesen
    DeActivateSignal(Output7) 'Auschalten des Druckluft Ventiels zum schliesen des Schutzes
    'Neues Werkzeug übernehmen bzw Werkzeug 0
    Call SetUserDRO (1200,NewTool)
    SetCurrentTool( NewTool )
    'Fahre auf Home Position
    Code "G28"
    Exit Sub
    End If
    'Aktuelles Werkzeug ist 0 also Spindel ist leer
    If OldTool = 0 Then
    'Schutz öffnen
    While IsMoving()
    Wend
    Code "G00 G53 A0"
    While IsMoving()
    Wend
    'Fahre Platz von Neuem Werkzeug an
    Call MovePos(NewTool)
    While IsMoving()
    Wend
    'Z Vorpossitionieren
    Code "G00 G53 Z" & ToolDown2
    While IsMoving()
    Wend
    'Fahre in Z auf Werkzeug
    While IsMoving()
    Wend
    'Werkzeug Spanner schliesen
    'Werkzeug ausrasten in Y
    Code "G01 G53 F" & Feed & "Y" & ToolBack
    While IsMoving()
    Wend
    'Fahre in Z auf sichere Position
    While IsMoving()
    Wend
    'Fahre in Z auf sichere Position Gnaz Oben
    While IsMoving()
    Wend
    'Schutz schliesen
    '##################Werkzeug länge messen######################
    If GetOEMDRO (824) <>0 Then
        Code "G0G53 Z" & ToolUp'Hochfahren in Z
    	While IsMoving()
    	Wend
    	code "g0 g53 x" & XSchalter 'x position des Schalters
    	While IsMoving()
    	Wend
    	code "g0 g53 y" & YSchalter'y position des schalters
    	While IsMoving()
    	Wend
    	code "g0 g53 z" & ZVorpos 'z position bis zu der im Eilgang verfahren wird
    	While IsMoving()
    	Wend
    	code "g31 z-1000 f500" 'erstes antasten
    	While IsMoving()
    	Wend
    	code "g53 g0 z" & GetOEMDRO(85)+3 'zusätzlich abheben
    	While IsMoving()
    	Wend
    	code "g31 z-1000 f50" 'fein tasten
    	While IsMoving()
    	Wend
    	Z_Shift = Schalter 'schalter höhe
    	Axis_Pos = GetOEMDRO(85) 'Z position des fräsers
    	Tool_Offset = Axis_Pos - Z_Shift 'offset berechnen
    	Call setOEMDRO(42, Tool_Offset) 'Werkzeug länge eintragen
            Code "G0G53 Z" & ToolUp 'fahre auf Save z
            Code "G28" 'fahre auf home position
            MsgBox "Ihr Fräsprogramm muss die Befehhlszeile G43 H" & GetOEMDRO (824) _
            & " M6 T" & GetOEMDRO (824) _
            & " für den Werkzeugwechsel enthalten"'824 ist die werkzeugnummer
    Else
    	MsgBox "Keine Werkzeug-Nummer gewählt",0
    End If
    '##################Werkzeug länge messen ende######################
    'Fahre an den Punkt an dem der Werkzeugwechsel aufgerufen wurde
    Code "G00 X" & x & " Y " & y
    Code "G00 A" & a
    Exit Sub
    End If
    'Loop falsche eingabe zu grose werkzeugnummer
    While NewTool > MaxToolNum
    NewTool = Question ("Geben Sie eine neue Werkzeugnummer ein bis max " & MaxToolNum)
    Wend
    'Wechsel zwischen Werkzeugen
    'Schutz öffnen
    While IsMoving()
    Wend
    Code "G00 G53 A0"
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    'Z Absenken vor und über dem Halter
    Code "G53 Z" & ToolDown2
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    'Neues Werkzeug anfahren
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    'Werkzeug langsam ausrasten in Y
    While IsMoving()
    Wend
    While IsMoving()
    Wend
    'Fahre in Z auf sichere Position Ganz Oben
    While IsMoving()
    Wend
    'Schutz schliesen
    	While IsMoving()
    	Wend
    	While IsMoving()
    	Wend
    	While IsMoving()
    	Wend
    	While IsMoving()
    	Wend
    	While IsMoving()
    	Wend
    	While IsMoving()
    	Wend
    	While IsMoving()
    	Wend
    Else
    End If
    Code "G00 A" & a
    End Sub
    Sub MovePos(ByVal ToolNumber As Integer)
    Select Case ToolNumber
          Case Is = 1
    	   XPos = -20.00
    	   YPos = -20.00
          Case Is = 2
    	   XPos = -40.00
    	   YPos = -20.00
          Case Is = 3
    	   XPos = -60.00
    	   YPos = -20.00
          Case Is = 4
    	   XPos = -80.00
    	   YPos = -20.00
          Case Is = 5
    	   XPos = -100.00
    	   YPos = -20.00
          Case Is = 6
    	   XPos = -120.00
    	   YPos = -20.00
          Case Is = 7
    	   XPos = -140.00
    	   YPos = -20.00
          Case Is = 8
    	   XPos = -160.00
    	   YPos = -20.00
    End Select
    Code "G53 X" & XPos & " Y " & YPos
    End Sub
    Main
    Re: ATC and Tool length sensor; While is Moving () is skipped; Emergency mode
    1) Is it actually hitting a limit switch, or just giving the error?
    2) Are you using a motion controller? If so, which one?
    No the limit switch is not touched, it only gives the error
    oh i forgot to mention that i have the china controler from novusun nvem V2 or something like that. I'm not sure how this is written right now.
    I hope I am not judged badly here because of my choice of controller. I know that there is no good opinion about this controller.
    At the moment I am considering whether I should switch to the CSMIO iP-S for 6 axes.
    Try to add a "sleep 50" inside the while loop, maybe will do the trick
    Regards
    Quote Originally Posted by sebba View Post
    Regards
    ok i will try this out.
    It may be noise triggering the input?
    As for the macro, it could be an issue with the plugin for your controller. Most Chinese controllers have some issues with Mach3 macros. The sleep might help. You might also want to try a different versions of Mach3, as most plugins work best with the version of Mach3 they were written for, and may have issues with other versions.
  1. How to get my tool length sensor to work in Mach3?
    By oddodd in forum Mach Software (ArtSoft software)
    Last Post: 03-21-2018, 04:21 PM
  2. Replies: 2
    Last Post: 01-31-2018, 12:53 AM
  3. Replies: 2
    Last Post: 10-16-2015, 12:48 PM
  4. Tool length sensor
    By krsykes23 in forum DIY CNC Router Table Machines
    Last Post: 01-24-2012, 11:50 PM
  5. tool length sensor parameters
    By kendo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-22-2011, 05:14 PM
