Re: Variable frequency 110V line 110v motor????
Many of the 1ph VFD controllers lost favoritism due to a tendency to drop out of run at low speed and/or loaded.
Hence the more popular 1ph input VFD to 3phase motor as Jim refers to.
Have you checked the type of motor you have?
One other motor that is commonly 1ph AC is the brushed Universal motor used in many appliances.
This can easily be controlled by a triac controller on AC as well as run on DC.
I converted mine using a now obsolete Universal motor controller once used in treadmills with a Universal motor.
Al.
Albert E.
