585,982 active members*
4,722 visitors online*
    Question Apprentice Siemens user question!
    Hi guys! I am an aspiring CNC technician (apprentice). I am currently doing training in the aerospace sector and the machines we are using run Siemens 840d. During my short time so far using our milling machine I have seen the command 'SUPA' used quite frequently. What does this mean? and is it siemens or machine specific?
    24221
    Re: Apprentice Siemens user question!
    Not sure of the meaning but one word on the Siemens control, if the 840D is anything like the earlier versions, occasionally the hard drive would crash, in this case it is imperative to clone a copy of the HD as Siemens used to charge a grand to replace a loaded drive.
    Al.
    Albert E.
    Sep 2002
    1956
    SUPA is Siemens specific. It stands for SUPress All.
    It is non modal G-Code suppressing "all" active zero offsets or more accurately all frames for one block-
    I wrote "all" in quotes because you may define the exact behaviour with machine data (for example you can define whether the offset of the currently active tool is to be ignored or not).
    SUPA is most often used when moving to the point for doing a tool change.
    Thankyou!
    Oct 2010
    134
    Here's a snapshot in the HELP of the conrol.
  1. Question to Pro4848 user
    By rarj in forum Avid CNC
    Last Post: 01-27-2016, 02:12 AM
  2. Fist time user Siemens Sinumerik 802C
    By gmolteni in forum SIEMENS -> GENERAL
    Last Post: 02-28-2015, 09:09 PM
  3. Replies: 2
    Last Post: 06-11-2013, 11:26 PM
  4. very new user question
    By LockTech in forum BobCad-Cam
    Last Post: 10-16-2009, 07:28 PM
  5. Gibbs user question
    By sunfire03 in forum GibbsCAM
    Last Post: 04-09-2008, 10:08 PM
