586,009 active members*
4,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > function of key in control panel
Results 1 to 6 of 6
    Nov 2007
    79
    Hi all
    can any one tell me the function of the button with key selector in the picture please?
    machine is doosan puma lathe with fanuc 21i TB
    Feb 2013
    788
    Re: function of key in control panel
    What is the serial number?
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    There is an Optional Enabling Keyswitch on some CE certified controls.
    It might be that...See attached.
    To confirm: Find that section of your electrical manual, get the -SK## from the schematic, open the operation panel and locate the backside of the keyswitch. It will be labeled with similar numbers.
    Nov 2007
    79
    Attachment 454490
    thank you for your reply dhardt:
    machine serial number is P35L3149
    i find this attached drawing in the electrical Circuit Diagram
    i need to know what this key does in operation for example, is it for program restart ?or maybe for spindle ?
    if you have similar operation control panel maybe you can help,
    i didnt find in the manuals any thing talk about this symbol
    thanx again for your reply
    Apr 2017
    29
    Looks like the Door Open switch . With it at "1" it allows you to handwheel the Axes for setting up with the door open .. If its never used them I assume you have overridden the safety interlocks.
    Nov 2007
    79
    of course I override the safety interlock its OCTG lathe
    any way i will try with the door after tomorrow and will tell you the result guys
    thanx for your reply Dale123
  1. Compensation function locked; stima Engineering compact tower software, simatic panel
    By KendorCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-09-2020, 04:53 PM
  2. Replies: 1
    Last Post: 02-19-2014, 02:19 AM
  3. CL 203 CONTROL PANEL
    By gtrrpa in forum Mori Seiki lathes
    Last Post: 04-22-2011, 08:15 PM
  4. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  5. My DIY control panel
    By DennisCNC in forum Community Club House
    Last Post: 10-03-2006, 04:24 AM
