585,992 active members*
5,225 visitors online*
    Dec 2006
    310
    Overcurrent Protection
    Dear Experts
    We have a SPM. Spindle motor is thro Star Delta contactor and overload relay with Main Contactor
    Spindle stopped running as its bearing sieged very badly
    Request to suggest better protective device having faster response to trip and avoid such seizure of bearings etc
    Thanks and Regards
    Nov 2012
    1267
    Re: Overcurrent Protection
    There should be a thermal overload relay between the contactor and the motor. The relay should be selected and adjusted for the nominal current of the motor.
    15362
    Quote Originally Posted by M.RISHIKESH View Post
    Dear Experts
    Thanks and Regards
    A Bearing can seize at any time, a thermocouple can be added to the bearing housing and set for to trip the contactor once it reaches it's max operating temperature most large AC motors already have overtemperature protection with built in thermistors if wired in to the system they to would of protected the motor
    If you are running a VFD Drive this is easy to setup to shut down if it see an over current, so as the bearing was getting hotter it would of been drawing a higher current and the VFD Drive would of shut down as an over current fault
    Mactec54
  1. Overcurrent and run away
    By ack1 in forum Dmm Technology
    Last Post: 05-25-2020, 06:47 PM
  2. Overcurrent-Leadwell
    By captainkaos in forum Servo Motors / Drives
    Last Post: 08-01-2015, 06:18 PM
  3. Overcurrent protection with WJ200 and Shinese spindle
    By NathanG34 in forum Spindles / VFD
    Last Post: 07-21-2015, 09:29 AM
  4. Overcurrent Detector
    By M.RISHIKESH in forum CNC Machine Related Electronics
    Last Post: 07-31-2013, 03:01 PM
  5. axis overcurrent
    By lovell110 in forum Haas Mills
    Last Post: 08-15-2007, 06:03 PM
