#nestingcncmachine
Attachment 454642
# X,Y,Z Working Area:2100x3000x200mm;
# Tool magazine: Carousel*type auto tool changer with 8*tools; ( Included 8pcs tool holders );
# Italy HSD Drilling head. 9pcs Vertical drilling+3pcs horizontal drilling + 1 saw. Model: H6318H0273;
# Automatic loading&unloading table, Auto labeling device;
#Vacuum and T-slot working table, 8*zones;
7.5KW Oil-free TONGYOU vacuum pump;
# Structure: 8MM New design steel structure;
# X, Y Structure: Rack and Pinion Drive, Taiwan PMI 25# Linear Square Rail;
# Z Structure:Taiwan PMI 25# Linear Square Rail and TBI Ball Screw;
# Spindle:*Italy 9.6kw HSD ATC air cooling spindle,
# Spindle Speed: 6000-24000RPM;
# Drive Motors: 850w Japan Yaskawa servo motors and drivers;
# Japan SHIMPO Reducer;
# Inverter: Taiwan 11kw DELTA inverter;
# Working Voltage: 380v, 3phase, 50HZ*
# Operating System: Taiwan SYNTEC6MB*control system with MPG handle wheel;
# Software:*ARTCAM*
# Lubrication system:New type 1.5L big Automatic lubrication
# Tool sensor:Automatic tool sensor calibration
#*1.5kw double bags dust collector system. Europe CE standard
# 8pcs vacuum pads
# High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand.
