585,727 active members*
3,971 visitors online*
    Wooden cnc 2x1 m belt driven cnc
    Hello everybody
    I decided to build my first cnc router,as cnc newbie i need some information and advices on design i choose to use and parts i picked to use.
    As first dimensions on machine should me around 2,2m x 1,4m machine,and 2m x 1,2x is travel
    Considering i am student i have pretty limited budget i decided to use belt drive system and supported(or unsupported) linear rails for moving my machine
    I would like to combine metal and wood in construction,my dad is carpenter so i have advantage in that part, he can help me choosing good wood and help me to work with it.
    For motors i choose nema 23 57HS82 (3 A 2.1 Nm) combined with HTD 5M belt 15mm width and 20th pulley,dual motors on y axis
    For rails i need to choose between unsupprted 20 mm linear shaft and sbr16 linear rail for X axis,for y axis i got 140cm long sbr20 linear rail i got for free from good friend
    I am worried about those sbr16 for y axis as i dont know if it is good enough for y axis,because going to sbr20 is little out of my budget for now.
    For z axis i can afford trapezoidal t8 leadscreew,and in that case i can choose lenght,or i can pick sfu1605/1610 280mm or 350mm length.
    Machine should be used for some basic v carving signs,letters etc. and if it is possible for some complex 3d model engraver or similar things like reliefs etc.
    I am still designing machine in fusion360 and i will post picture how i thoght to build it in few days
    Apr 2004
    5734
    Re: Wooden cnc 2x1 m belt driven cnc
    Supported rails work a lot better than unsupported ones. The longer they are, the more this counts.
    Andrew Werby
    Website
    I assumed that will be the answer,thank a lot
    And what do you think about those nema 23 i choose,is that enough torque.
    I am little worried about it because i kinda bad at those calculations,i choose it more by size...
    Quote Originally Posted by awerby View Post
  1. Belt Driven Z Axis
    By FreeRider in forum Momus Design CNC plans
    Last Post: 05-31-2017, 06:47 AM
  2. New CNC build with belt driven Z
    By n0rth3rnlight in forum DIY CNC Router Table Machines
    Last Post: 04-18-2015, 07:18 PM
  3. direct driven or belt driven
    By jeremy0203 in forum Benchtop Machines
    Last Post: 07-27-2011, 05:23 AM
  4. belt driven CNC
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 11-29-2008, 11:10 PM
  5. Belt driven screw ?
    By tomcat47 in forum Linear and Rotary Motion
    Last Post: 01-29-2007, 05:20 PM
