585,962 active members*
3,939 visitors online*
    Dec 2020
    Mazak AJV-25/405 Lost positional data
    We are looking at buying a Mazak AJV-20/405 I believe a 1988 year model. I went and looked at it and the owner of it knows nothing about it. It was left in the building he had purchased. It has been powered down for over a year now and it seems to have lost all of its positional data. Does anyone know how one of go about teaching the positions? This machine is older then anything I have ever ran or worked on before so its a little out of my wheelhouse. Any information or manuals of any kind would be appreciated.
    May 2013
    149
    I remember from 2000, memory battery dying and replaced, the core of the computer was a big red box with 'meldas' printed on the side, it had a 3.5 floppy disk drive.
    A company called 'john hart' (australia) brought a disk and reloaded all the parameters.
    If this exceeds your budget, then replace battery and type in manually all the missing parameters.
    This can be dangerous, perform tests at low rapids with maybe a texta in a chuck, foamblock workpiece.
    Wisdom results from foolishness!
    Dec 2020
    Re: Mazak AJV-25/405 Lost positional data
    Thanks for the information. We ended up passing up on the machine, couldn't risk it not working.
    Feb 2021
    10
    Quote Originally Posted by cmiles View Post
    In the future, mazaks with a 640m/t control will Jae some type of back up on the hard drive. You just download it. Setting an axis up wouldn’t be hard because you are using switch and dog home.
  1. MSD data lost Emco Pc mill 125
    By Beefheart in forum EMCO Mills
    Last Post: 07-28-2016, 03:50 PM
  2. FH6800
    By jimica in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2013, 10:49 AM
  3. Fanuc 0M, Miyano TSV-25, data lost
    By sinad in forum Fanuc
    Last Post: 04-05-2013, 08:33 AM
  4. lost Data hitachi seiki HT 20
    By emind in forum Fanuc
    Last Post: 10-19-2011, 08:21 AM
  5. rover 336 data lost
    By freezengate in forum CNC Machining Centers
    Last Post: 11-17-2010, 10:07 PM
