585,975 active members*
4,614 visitors online*
    Dec 2009
    17
    Amada HFB8025 bowing material
    Hi Guys,
    I recently purchased a used Amada HFB 8025 8' press brake. Purchased all new tooling, punch holder, punch, die rail, die. What is happening when I bend material is it is bowing it in the middle. The angle is consistent in the middle as it is on the ends, so it's not canoeing, but bowing the length of the bend. Not sure if this a common deflection issue?
    Any suggestions would be appreciated.
    Thank you,
    Greg
    Feb 2021
    5
    Re: Amada HFB8025 bowing material
    Le mien est HFBO8025 -1996.
    Cependant, je recherche une version électronique de l'instruction pour la traduire en bulgare. Quelqu'un peut-il m'aider?
  1. Aluminum Stamping Bowing
    By KE6CVH in forum MetalWork Discussion
    Last Post: 02-09-2014, 09:51 PM
  2. Engraving Material Bowing
    By cainam in forum Engraving Machines
    Last Post: 07-19-2011, 05:55 AM
  3. Bowing aluminium when pocketting
    By Lugy in forum MetalWork Discussion
    Last Post: 10-29-2010, 12:16 AM
  4. My base is bowing
    By guru_florida in forum DIY CNC Router Table Machines
    Last Post: 05-23-2008, 07:37 PM
  5. Keeping the cutting bed from bowing?
    By matt888 in forum Commercial CNC Wood Routers
    Last Post: 01-07-2008, 10:11 PM
