585,754 active members*
3,807 visitors online*
IndustryArena Forum > CAD Software > Solidworks > please, help with a bunch of questions :)
Results 1 to 7 of 7
    Jun 2015
    4154
    hello please, i have a few questions :
    - how to reverse scroll direction when zooming ? it's behaving opposite in comparison to autocad ...
    - it's required to close a contour, in order to revolve it; when creating the drawing, if i put a centerline, it won't be displayed properly, because behind it is the line that closed the countour; how to display a centerline on a drawing, of a revolving part ?
    - also, please check attached images / kindly
    Jun 2015
    4154
    Re: please, help with a bunch of question :)
    ... and here, 2 more images / thank you
    Jun 2015
    4154
    Re: please, help with a bunch of questions :)
    Mar 2008
    683
    All fairly easy to change with your sheet format and part formats. You'll need to make template files. Every time you start a new part or drawing it is pulling up the default SW templates.
    Apr 2013
    6
    Quote Originally Posted by deadlykitten View Post
    Options (gear symbol at top of screen), System Options, View. The "Reverse mouse wheel Zoom direction" option is at the top.
    Apr 2013
    6
    Just draw a "construction" line on top of the line that defines your axis. Usually I draw the construction line BEFORE closing the contour for a revolved feature. I just make the "construction" line longer than the line used to close the contour. Additionally, if the construction line is present in your sketch before you press the revolve button, SW will automagically choose the construction line as the axis to revolve about. Saves a button click.
    Jun 2015
    4154
    hy 3d botic, thank you for your answers
    please, if you have time :
    ... there are pictures with questions in post 1 & 2 , about drawings
    ... same in this post, about mbd
    ... do you use cam in solidworks ? kindly
  1. UPS a big bunch of BS
    By Steve Seebold in forum Tormach Personal CNC Mill
    Last Post: 04-02-2019, 06:07 PM
  2. I was given a bunch of CNC parts
    By rudt_t in forum DIY CNC Router Table Machines
    Last Post: 12-29-2013, 10:13 PM
  3. Bunch of stuff FS G540
    By Starleper1 in forum Benchtop Machines
    Last Post: 08-01-2011, 11:37 PM
  4. A bunch of whoi
    By jsage in forum Environmental / Alternate Energy
    Last Post: 03-13-2007, 06:17 AM
  5. Got a bunch of VFD's, anything good?
    By dar303 in forum Phase Converters
    Last Post: 05-22-2006, 02:31 PM
