585,933 active members*
3,878 visitors online*
Results 1 to 7 of 7
    Jun 2015
    8
    DIY Servo press
    Does anyone made a DIY/small shop servo press?
    Jun 2015
    8
    Re: DIY Servo press
    I'm looking to a servo press with force cca 10 kN. The price of complete presses are far above my budget, so I'm considering what's my options to build one. The frame of the press will not be a subject here, but only the main part of it - servo linear ball screw actuator.
    I know the servo presses of similar power consist of a ball screw, gear pack, and of course a servo motor.
    The question is: what's the math behind it? I think I seen somewhere that 10 kN servo presses use a 750 W AC servo drive. I would like to know which gear pack and ballscrew diameter would be good to go?
    Attached Thumbnails Attached Thumbnails 73A7CD0C-9DB0-4BEB-8DFE-8131267BA13E.jpeg
    Oct 2010
    46
    Re: DIY Servo press
    I've seen some calculations here:
    https://mechextreme.blogspot.com/p/design-symbol.html
    if gear reducer is used, depending of ratio it could use a smaller servo size and power.
    some formulas and calculations more detailed here:
    https://www.orientalmotor.com/techno...culations.html
    Some other links useful, maybe ?
    https://www.motioncontroltips.com/8-...servo-systems/
    https://www.thefabricator.com/stampi...-servo-presses
    https://enginexcel.com/servo-motor-sizing
    AXYZ Millennium router CNC: https://goo.gl/gxvdcA
    Glass cutting CNC table: https://goo.gl/VrDqGD
    Dec 2006
    51
    Re: DIY Servo press
    The first thing you need to determine is the speed of the press while applying the 10kn force. That will tell you what size servo motor is needed. Then I think you need to know the frequency of cycles and the distance (travel) the force is applied.
    Jun 2015
    8
    Re: DIY Servo press
    wow!
    thanks! A LOT of useful links!
    Jun 2015
    8
    Re: DIY Servo press
    So far, I like this ''wall' design ( not sure how it really calls ) better than the cylinder design (ball screw/ball spline combination).
    let's call it the ''wall'' design is much easier to me to build.
    But, I'm pretty confused about the ''fixed-free'' bearing style on this servo press design. As far as I know, ''fixed - fixed'' bearing system is much more rigid and allows faster movement.
    Anyone knows whats the catch?
    Jun 2015
    8
    Quote Originally Posted by klxrcr View Post
    I need around 10mm/s (0,4”/s) speed.
    Stroke is max 25 mm ( cca 1 inch).
    Which size servo do I need?
    Thank you
  1. Looking for help to add a servo motor to a press brake back gauge
    By CPrice9720 in forum Servo Motors / Drives
    Last Post: 11-10-2020, 08:47 PM
  2. Press brake tools, bending tooling for press brakes from Italy
    By pressbraketools in forum News Announcements
    Last Post: 05-19-2018, 11:06 PM
  3. Replies: 2
    Last Post: 11-17-2014, 11:30 AM
  4. Servo controlled Punch Press Head
    By rrossey in forum Uncategorised MetalWorking Machines
    Last Post: 05-22-2012, 11:23 AM
  5. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
