585,761 active members*
4,068 visitors online*
Results 1 to 3 of 3
    Nov 2020
    BLDC driver using STM32F103
    Hello to everyone here.
    I recently stumbled upon very good project here:
    https://www.cnczone.com/forums/open-...28-cnc-24.html
    It seems that this thread was closed long ago .
    I am a hobbyist in electronics. Have made some small projects using Arduino. I made a working small CNC router using Arduino UNO and stepper motors.
    Now Im trying to make bigger CNC which will need higher feed rates. So I was searching for BLDC servo solution, and found it hare.
    This looks like realy good project to implement cheap BLDC motors for motion control.
    Anyway, I started to make this project.
    MCU is conecting to Servo Tuner app
    the app is showing encoder position
    But, I decided to test signal to driver stage and I get weird results. pins PB15, PB14, PB13, PA10, PA9, are HI, and PA8 is LO. This will result in magic smoke if I connect MOSFETs.
    I plan to use FDD8896 MOSFETs and drive them dirrectly from MCU. Allready tested to switch them dirrectly and works just fine.
    So can someone please help me hare?
    Nov 2012
    1267
    Re: BLDC driver using STM32F103
    Are you sure you have steady HI level on those pins (not high frequency PWM)? Did you check it with a scope or just a voltmeter?
    Nov 2020
    Quote Originally Posted by CitizenOfDreams View Post
    Actually I checked with scope too. It gives 5 Hz with 0.8 v drop. So steady hi.
  1. Help! AC bldc driver to 48v motor
    By crl1_1 in forum Milling
    Last Post: 04-07-2020, 04:29 AM
  2. Sangmutan BLDC Motor and Driver
    By Rotosan1980 in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2013, 08:05 PM
  3. Allegro 3938 BLDC driver board
    By originator in forum Open Source Controller Boards
    Last Post: 05-11-2011, 01:50 AM
  4. Very High cost-efficient BLDC Driver
    By zihuiqi in forum News Announcements
    Last Post: 11-28-2008, 01:26 AM
  5. cost-effective BLDC driver
    Last Post: 05-18-2008, 01:24 PM
