585,908 active members*
3,588 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)
    Hello,
    i put a scheme of what i want to do :
    I bougth a piece of card (Z80, CPU683 68EC020 PLC Tecnos system and input / output) for upgrade my cnc Master Project 323 who's working correctely with his old system under Dos ... but not very easy to use
    These cards was working into a Masterwood Project 309 retrofitted
    I replace old card (68000 named 681) by 683
    and Z80 Si_89 by Si_96
    I wonder if someone could help me to introduce good parameter to make it working ?
    With some photos of retrofit of the Masterwood :
    this new CPU3-2M CPU68EC020-2003-01 (31SFC104640) card
    will replace the older CPU1 (68000) KTC91
    new old
    The old I/O cards (ACCTC90/02) will be replaced by new I/O cards 61SFA300101 (ASSI_CC_2007_01)
    The communication interface Si2.5 is replaced too by SFS10150 SI_96_01 (31SFS101460)
    and RamDisk Card is suppressed because no need anymore
    the software MasterWork drive everything
    To be followed,
    Regards, GLP
    Re: Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)
    Hello,
    some pictures of what I want to do
    is there anybody in the place who knows Tecnos controller ?
    specialist of Masterwork parameters ?
    Thanks, bye.
    Attached Thumbnails Attached Thumbnails config IO MasterWood Project 323 running.jpg
    Nov 2009
    5
    The sw in the pic in the DOS version of machine HMI.
    The firmware on 68000 card isn t compatible with the CPU 683, the SI2.5 could be compatible with both CPU.
    The axes card can depend on the firmware too
  1. Masterwood Project 319-323
    By Tarpin in forum Commercial CNC Wood Routers
    Last Post: 01-28-2022, 08:38 PM
  2. Masterwood Retrofit
    By leprovostgildas in forum CNC Machining Centers
    Last Post: 12-29-2020, 04:41 PM
  3. Masterwood Project 313
    By 9thraven in forum CNC Machining Centers
    Last Post: 02-28-2018, 04:46 PM
  4. Control Retrofit for 1993 Fadal 6030
    By dunnitagain in forum Fadal
    Last Post: 07-19-2015, 11:49 PM
  5. Masterwood Project 416 K
    By Chad1 in forum CNC Machining Centers
    Last Post: 01-24-2012, 10:28 AM
