584,858 active members*
4,570 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Align X ballscrew Fadal 3016
    Oct 2014
    38
    Hi folks, I am changing my thrust bearings in a Fadal 3016 X axis and I need to realign the screw, I am a bit at a lost on how to do that for what I understand I would follow this steps after the ball screw is instralled...
    1.- Tighten the ballnut to the table leaving the mounts finger tight. (should this be done mid travel on the ballscrew?)
    2.- Move the table to the the thrust bearing side and tighten that side.
    3.- Move the table to the carrier bearing side and tighten that side.
    4.- Move the table to the middle of the travel loosen and then tighten the ballnut mount.
    Does that sound correct? Thank you all in advance
    Feb 2007
    171
    Re: Align X ballscrew Fadal 3016
    That's how I'd do it, then do an amp clamp test running about 150ipm the length of table travel and measure the current going out to the motors. Make sure it' 3 amp or so not under load.
    Oct 2014
    38
    Thanks ASIGuy! I appreciate the help.
  1. WTB Fadal VMC-3016 or VMC-15
    By Recoil6 in forum Fadal
    Last Post: 06-14-2018, 07:18 AM
  2. Fadal VMC 3016 I Need Help PLEASE!
    By HBZ USA in forum Fadal
    Last Post: 08-07-2010, 07:11 PM
  3. 3016 ballscrew backlash
    By Daniel Boone in forum Fadal
    Last Post: 07-20-2010, 07:00 PM
  4. Wiring a '96 Fadal 3016 to a RPC
    By FadalNewbie in forum Fadal
    Last Post: 09-25-2009, 11:21 PM
  5. Reman Fadal 3016 Questions
    By RDTS in forum Fadal
    Last Post: 11-20-2008, 04:12 PM
