585,735 active members*
4,761 visitors online*
    Dec 2020
    Another Powace 6040Z, not moving
    Hi
    I recently bought 2 Powace 6040z machines and I can't get them to move. For troubleshooting I have been able to try software on both of them.
    Been looking around on this forum and the only other post I could find with the same machine, or at least USB motion controller card as mine, have had no replies.
    I have tried with the drivers and Mach3 software send over by the seller after contacting them. I have also tried a bunch of other drivers suggested in threads here without any success as well.
    Been trying it on a Windows 10 64 bit, and a clean install of Windows 7 32 bit. The screenshots attached are from the Win7 install.
    I get the error message in Mach3 of "No UsbMachBoard, please plug it in!"
    I hope someone can help me out to identify the USB controller board or the right drivers to use, or anything really.
    Thanks.
    Re: Another Powace 6040Z, not moving
    Quote Originally Posted by BTheKid2 View Post
    Hi
    Thanks.
    I think you might be missing the plugin for usb:
    here is what I could find on the installation and opperating this machine.
    https://hl-yeah.com/uncategorized/ch...-router-setup/
  1. Powace Cnc 6040Z 4 axis usb, not working
    By frappu in forum Chinese Machines
    Last Post: 12-31-2020, 05:57 AM
  2. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  3. Design Options: Moving bridge vs. Moving Cross Beam
    By martin_05 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 08:20 PM
  4. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
