585,894 active members*
3,881 visitors online*
Results 1 to 6 of 6
    Dec 2006
    310
    Pressure Drop in Chuck
    Dear Experts
    We have a turning machine with chuck having hi/lo pressure. Required pressure for Hi chucking pressure is 15 bars and for low it is 8 bars
    Problem that we are facing is during changeover from hi to lo chuck pressure, hi pressure is increasing upto 18 bars and lo upto 11/12 bars
    Please refer to spec of valve attached
    We have taken following actions :
    1. Taken out and serviced hi ands low pressure direction control valve - manually pushed the valve to feel movement of spool inside, found alright
    2. This valve operating with 110VDC, replaced valve with valve operating with 24V DC - after electric modification via relay
    3. Check valve opened up and serviced
    4. No leakages observed in the hydraulic power pack
    Request your suggestions
    Regards
    Dec 2013
    5717
    Re: Pressure Drop in Chuck
    Without knowing more about the system, it is difficult to say what the problem is.
    Where is the pressure being measured? At the chuck cylinder ''A'' or ''B'' line, or on the ''P'' line to the valve?
    The valve in the picture is a closed center valve, so ''P'' would show pump relief valve pressure when switching.
    Once the valve has shifted, does the pressure remain at 18 or 11 bar?
    Is the pressure gauge reading correctly? Measuring against another known good gauge is sometimes required.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2006
    310
    Apologies for late response
    Both hi and lo Pressure connected to P line of Pressure reducing valve
    After changeover from hi to lo, hi pressure increases upto 18 bars (from 15 bars) and lo pressure increases upto 11 bars (from 8 bars) , both remain at 18 and 11 respectively for entire machining of component
    We have swapped pressure gauges with other OK sets, still it is same & moreover once we found job got slightly declamped from jaws of chuck although did not come out of it completely
    We are organizing new set of Check valve and Pressure reducing valve for replacement as servicing of these two valves did not yield any difference
    Regards
    Dec 2013
    5717
    What is the pressure at the chuck actuating cylinder? Is the cylinder leaking internally?
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by M.RISHIKESH View Post
    Dear Experts
    Regards
    Very straight forward the Pressure Relief valve is not working correctly, or some one has adjusted the Pressure Relief valve, for it to have a higher pressure
    Mactec54
    Dec 2006
    310
    Thanks for your response, we found some issue in precondition ie Casting also, ok under observation
  1. Newtonian Pressure Drop vs Non-Newtonian Prssure Drop
    By Siraj77 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-29-2016, 08:06 AM
  2. Looking For Pressure Drop Correlations Of Non-Newtonian Two-Phase Flow in The Pipelin
    Last Post: 10-24-2016, 06:12 AM
  3. chuck pressure alarm OKUMA
    By Fabio1 in forum Okuma
    Last Post: 12-02-2014, 01:04 AM
  4. Chuck high low pressure
    By MCR-B II in forum Okuma
    Last Post: 07-23-2011, 07:22 PM
  5. Measuring the pressure drop down a pipeline
    By martinw in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2008, 05:01 AM
